Furuno 1712 repair tec. - SailNet Community
post #1 of 5 Old 04-13-2014 Thread Starter
I have a Furuno 1712 radar. it came with the boat. the previous owner said he had a problem with the scanner belt which was easily fixed by a Tec.
I was wondering anyone can recommend a Furuno repair Tec . In the Victoria or Vancouver BC area.
I can bring boat to either.
I don't know if this is the problem. the display turns on but there is nothing but a blank screen.
Uricanejack is offline
post #2 of 5 Old 04-13-2014
Courtney the Dancer
jrd22's Avatar
Re: Furuno 1712 repair tec.
Try reconnecting the 3 (?) multi pin connectors in the radome. Even if they look clean I've had this same problem and disconnecting/reconnecting solved the blank screen for me.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 5 Old 04-13-2014
Dog Ship's Avatar
Anchor Marine Electric, great guy's great store. They'll fix your problem.
http://www.google.ca/url?sa=t&rct=j&...64542518,d.aWc
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #4 of 5 Old 04-14-2014 Thread Starter
Thanks
I will try the unplug and plug in again.
And give them a call if it doesn't work
post #5 of 5 Old 05-01-2014 Thread Starter
Was away for a couple of weeks.
Took the RADAR mast down today to get to the scanner was intending to unplug and take to repair shop.
Found there is no plug wire goes straight into the dome.
took dome of the pedestal and took cover off. Wiring looked to complicated for me to disconnect.
found the belt was off and small wheel on motor fell off.
put belt back on and used Allen key to tighten Allen screw for drive motor wheel.
Put mast back up to see what would happen. RADAR works now.
Not 100% sure but I think I may have screwed up the heading alignment.
Boat sitting in dock so lots of targets.
I donít have an installation manual.
Dome has two small arrowís which were only external markings apart from green mildew.
Placed them forward.
Mast is back in position I think aligned as before. Unfortunately itís a home made carbon mast not a pro install.
The belt has notches, both the motor wheel and scanner wheel have teeth. Is it possible they should be in a specific alignment?
Furuno GP-35 to Laptop Smourt General Discussion (sailing related) 1 10-22-2011 02:57 AM
Spin Tec Triumph 2000 furlers ???????? sailbear50 Gear & Maintenance 0 11-17-2009 11:10 PM
Energo-Tec trantor12020 Gear & Maintenance 5 10-20-2008 12:22 AM
Outboard Motors E TEC verses the others dsbentley Gear & Maintenance 4 05-24-2006 08:26 PM
furuno installation emmylouhairball Gear & Maintenance 0 06-26-2005 09:44 AM
