Filling voids prior to gel coat ? - SailNet Community
 1Likes
  • 1 Post By divimon2000
post #1 of 8 Old 04-17-2014 Thread Starter
Hi all,
I have several void on my deck where the fiberglass is showing and the gelcoat had chipped away. Also some small chips.
What is the best product to apply to the bare fiberglass prior to applying the gelcoat?
I've seen talk of a product called Rage and also something by 3M but I'm not sure if this is correct.
Can anyone out there clarify?
Thanks
pfile is offline
post #2 of 8 Old 04-17-2014
RichH's Avatar
Re: Filling voids prior to gel coat ?
The best 'filler' for small 'voids', gouges, etc. when repairing gelcoat = "Cabosil" aka: WEST SYSTEM Colloidal Silica filler #406.
RichH is offline
post #3 of 8 Old 04-17-2014 Thread Starter
Hi Rich,
Thanks for your response. I do actually have some of this on hand, West Sytem and cabosil.
The reason I asked and thought that perhaps the West was not good for this purpose was that I seem to recall reading conflicting reports about gel coats adhesion to epoxy?
Not sure, I'm quite new to this though.
pfile is offline
post #4 of 8 Old 04-17-2014
BluemanSailor's Avatar
If your going to gelcoat afterwards the best product, especially for adhesion and sand ability is Evercoat 27.
Sands easily and great for fairing out any voids. Then gelcoat.
Stay away from cabosil- that's mainly used for bonding and filleting- hard as hell to sand!
Roland
Sailor - kayaker - woodturner - Photographer.
New boat sailblog -
BluemanSailor is offline
post #5 of 8 Old 04-19-2014
Agree with above post. Gel is polyester, so use 3m green or other polyester concoction. Gel won't bond well with epoxy so don't use west system epoxy. The "filler" material (cabosil) is irrelevant to that bonding process
boatpoker likes this.
divimon2000 is offline
post #6 of 8 Old 04-19-2014
overbored's Avatar
gel coat adheres to cured epoxy just as well as cured polyester.
WEST SYSTEM | Projects | Fiberglass Boat Repair and Restoration - Polyester over epoxy
My forty years of experiance says the same thing
"GOLD RUSH" PRINDLE 16
overbored is offline
post #7 of 8 Old 04-19-2014
Evercoat say not so. It says on the can do not use over epoxy because of the bonding problem. I just saw this about 3 hrs ago looking at gelcoat listing for repairs on my own boat!!!!
mike dryver is offline
post #8 of 8 Old 04-19-2014
overbored's Avatar
read the article and you will see it does adhere to cured poly about the same as epoxy. but it does work and very well. here is an instrument mount hatch cover, evercoat over west about 4 years old and still looks new. get stood on almost ever time the main goes up
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 09:08 PM
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 07:33 AM
Filling holes in hull with epoxy barrier coat slugchewer Gear & Maintenance 12 09-02-2008 11:40 PM
Recommended tool for opening up cracks prior to filling and fairing GBurton Gear & Maintenance 15 11-17-2007 01:45 PM
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
