Removing painted numbers over gel coat - SailNet Community
post #1 of 6 Old 04-22-2014 Thread Starter
krazzz's Avatar
I have some faded registration numbers painted on my boat and want to remove them. It is a fiberglass boat with a gelcoat finish. What can I use to safely remove the numbers without harming the gelcoat? I do not know what type of paint it is but it appears to have been on there for a couple decades.
Ludington, Michigan - Lake Michigan
1971 Ericson 32 Hull # 193
1974 Catalina 22
krazzz is offline
post #2 of 6 Old 04-22-2014
Re: Removing painted numbers over gel coat
Try a little Citrustrip. It doesn't harm fiberglass.
Seaduction is offline
post #3 of 6 Old 04-22-2014
Master Mariner
capta's Avatar
Every professional boat name painter I've ever met uses Easy Off to remove painted on names from gelcoat. I've used it a few times and it does a great job. Spray, give it a few seconds to a couple of minutes, then wipe off paint, rinse thoroughly, rinse again. Do not let it get on other painted surfaces or varnish.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #4 of 6 Old 04-23-2014 Thread Starter
krazzz's Avatar
I have so Easy off so I will give that a try first. If it doesn't work I will give citrustrip a try. Thanks!
1974 Catalina 22
krazzz is offline
post #5 of 6 Old 04-23-2014
I've always used acetone.
No matter what you use, if the numbers have been there for years as you say, you will see residuals. Best described as almost an etching from the UV that exposed the gelcoat where the painted numbers weren't. Sanding will be the only thing to really get all of it out. Start with something like 400 and work up to 1000 or so, wet sanding.
Multihullgirl is offline
post #6 of 6 Old 04-23-2014
christian.hess's Avatar
I wet sanded....but I like the easy off idea
man so many uses for stuff...I used easy off to clean cyclinder heads and the like on my motorcycle
jajaa now someting else
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Tags
gelcoat , paint , removal
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 09:08 PM
Removing painted letters Pegu club General Discussion (sailing related) 23 04-25-2013 05:31 AM
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 07:33 AM
removing painted numbers from inflatable anemoneii Gear & Maintenance 9 03-25-2010 08:54 PM
removing painted boat name maureena5 Gear & Maintenance 1 02-20-2001 06:08 AM
