Stuck Impeller - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 04-28-2014
Wonderinlost's Avatar
Re: Stuck Impeller
Originally Posted by nccouple View Post
Dremel tool, cut a grove in it and pop it with a small hammer and chisel. Butane torch would do the trick also but might catch your boat on fire when the rubber takes off, so ignore the last idea. Defiantly put antisieze on it when you go back with the new one.
I agree if you can cut a grove in it to the shaft. Just like removing stubborn berring races on a trailer.
Wonderinlost is offline
post #12 of 13 Old 04-29-2014
Re: Stuck Impeller
I just had to use a dremel tool to get the hub out of my old 9.8 Merc outboard waterpump. Worked well.
Frogwatch is offline
post #13 of 13 Old 05-09-2014
DrB
Another aproach
put two rags on the edge of the impeller housing so you don't damage the edge. Jam two larger flat head screwdrivers, opposite each other into the impeller barrel based (as close as you can) at an angle and against the rags. At the same time, push down of the screwdrivers to pry off the impeller. I couldn't pull mine off by the other methods, but this method popped it right off.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
impeller issues RNC725 Atomic 4 4 01-12-2011 11:04 AM
Impeller issues... tkawika Gear & Maintenance 5 10-27-2010 11:04 PM
Looking for Renault RC-8D impeller sautersargent Gear & Maintenance 6 02-10-2010 09:30 AM
impeller change ralphmacey Gear & Maintenance 14 11-20-2007 02:18 PM
Impeller is sticking. jr438234606 Gear & Maintenance 2 06-27-2006 12:13 PM
