Stuck Impeller - SailNet Community
 2Likes
post #1 of 13 Old 04-28-2014 Thread Starter
Stuck Impeller
So the last time I changed the water impeller it took some work, but it came off.
Not so this time. Would not budge. And now all the vanes are torn off and I'm left w/ the damn hub stuck on and no way to run the engine to boot!
Even thought about shelling out big bucks for a fancy impeller puller, but Noooo, the one at the local Marine store was for big impellers. Mine is 1 9/16".
Any ideas?
CS 36M DIANTHUS
sailordave is offline
post #2 of 13 Old 04-28-2014
Re: Stuck Impeller
Your impeller is as they say locally "wicked small."
I'd try grabbing it with these and giving a yank.
http://www.jsproductsinc.com/media/3599.jpg
capecodda is offline
post #3 of 13 Old 04-28-2014 Thread Starter
Re: Stuck Impeller
All that's left is the hub. Nothing really to grab onto.
CS 36M DIANTHUS
post #4 of 13 Old 04-28-2014
Re: Stuck Impeller
maybe try some PB Blaster, let it stew. ?
tempest is offline
post #5 of 13 Old 04-28-2014
Barquito
Barquito's Avatar
Re: Stuck Impeller
I find that the correct swear word incantation works. The trick is finding the right words in the right order: Usually G*d d#mb m@th*r f^(king sum bee-atch does the trick. If not then I reach for PB Blaster and a bigger tool.
arf145 likes this.
Valiant 32
Barquito is offline
post #6 of 13 Old 04-28-2014
Re: Stuck Impeller
Maybe remove the pump and take it to a machine shop ?
"Just call me TB"
capttb is online now
post #7 of 13 Old 04-28-2014
Master Mariner
capta's Avatar
Re: Stuck Impeller
Unfortunately, what you are getting into here is the possibility that you have or will destroy the seal in the process of removing the impeller hub. Removing the pump and getting it in a vice or at least on a bench, will probably help. Soaking the pump in diesel for a few days or longer might help, if the Blaster isn't doing the job. You may have to completely disassemble the pump and get the shaft out to fix this, At any rate, it's probably going to take vice grips and a hammer, which will surely destroy the seal.
Look around for a used pump that you can keep around (after rebuilding) to use for a quick change out, if an impeller goes.
Next time, lube the shaft with Never Seeze and you won't have this problem again.
trantor12020 likes this.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #8 of 13 Old 04-28-2014
Thumbs up Re: Stuck Impeller
This happened to me just 3 days ago. Sailing to Subic Bay in the Philippines I overnighted in a little backwater and left the next day overheating. It was time to replace the impellor but could not get it out and only, like you, had the hub. I got a vice grip on it perpendicular to it and could not wiggle it off. Placed a large (1 1/2 foot) screwdriver through the hole between the impellor and the jaws then something on the waterpump to keep the tip from scratching and levered it right off. Had to return again to pick pieces of rubber out of heat exchanger.
good luck
DocBrauer is offline
post #9 of 13 Old 04-28-2014
night0wl's Avatar
Re: Stuck Impeller
The good thing is...a water pump is really only $200
S/V Jendai
Beneteau 343
night0wl is offline
post #10 of 13 Old 04-28-2014
nccouple's Avatar
Re: Stuck Impeller
Dremel tool, cut a grove in it and pop it with a small hammer and chisel. Butane torch would do the trick also but might catch your boat on fire when the rubber takes off, so ignore the last idea. Defiantly put antisieze on it when you go back with the new one.
oursailingadventures.com
nccouple is offline
The Following User Says Thank You to nccouple For This Useful Post:
Wonderinlost (04-28-2014)
impeller issues RNC725 Atomic 4 4 01-12-2011 11:04 AM
Impeller issues... tkawika Gear & Maintenance 5 10-27-2010 11:04 PM
Looking for Renault RC-8D impeller sautersargent Gear & Maintenance 6 02-10-2010 09:30 AM
impeller change ralphmacey Gear & Maintenance 14 11-20-2007 02:18 PM
Impeller is sticking. jr438234606 Gear & Maintenance 2 06-27-2006 12:13 PM
