C&C 30 MK1 Shifter help. - SailNet Community
post #1 of 5 Old 04-28-2014 Thread Starter
First String
SO,
Its time to change the shift cable on my 1981 C&C30 MK1. The cable that is there now has always been tight and hard to shift. Is there a better style or different cable to make the shifting easier? I just got back from the BVI we Where we rented a 36-I and it shifted very nice. I have never owned a different sail boat and there-fore had nothing to judge by. But now after a week with great shifting I think its time to change mine out. My boat has a red cable. my shiftier is on the left of the console and the throttle is on the right side. The throttle seams fine. Any Suggestions?
Thanks for your help and advice.
LT,
ltgoshen is offline
post #2 of 5 Old 04-28-2014
Chastened
Ajax_MD's Avatar
Re: C&C 30 MK1 Shifter help.
I think you have an Atomic-4 with an old Teleflex cable.
Why don't you try lubricating it before replacing it? Remove the cable, and hang it in your garage. Apply ATF fluid to the inner, moving part and let it run down into the casing for about 30 minutes. Then, try to operate the cable and work the ATF around.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #3 of 5 Old 04-28-2014
no longer reading SailNet
Alex W's Avatar
Just replace the cable. The existing 33 year old one is probably corroded. A new Teleflex cable (or almost any other suitable replacement) will probably be a nice upgrade.
You should also check the transmission oil. I accidentally used the wrong oil (30W instead of 10W30) in my Yanmar 2GM20F transmission and it killed the shifter feel. A got back to the dock and put in the correct oil and the shifting got precise once again.
Alex W is offline
post #4 of 5 Old 04-28-2014 Thread Starter
First String
I have a 2GM20-F As well. the thing is, if I take it lose from the moves easy. The trans shifts by hand very easy as well. Its just when the two are connected it becomes stiff and hard to shift?
Thanks
ltgoshen is offline
post #5 of 5 Old 04-28-2014
Alex W's Avatar
That suggests that you do need a new shift cable. Mine was stiff even when you disconnected the shift cable.
Alex W is offline
C&C 30 MK1 its officially mine ltgoshen General Discussion (sailing related) 23 01-14-2016 04:53 PM
C&C 30 MK1 Shift cable Help... Please ltgoshen Diesel 1 08-28-2013 05:44 PM
C&C30 MK1 What halyard to use? ltgoshen General Discussion (sailing related) 18 06-10-2013 04:33 PM
polars for C&c 29 mk1 hairybear29@att.net Racing 0 12-10-2012 12:19 PM
Stiff Shifter Yanmar 4JH2E volvo penta shifter/throttle adam Gear & Maintenance 7 06-16-2008 11:11 AM
