Winter vs. Summer Sails - SailNet Community
post #1 of 6 Old 04-29-2014 Thread Starter
This is likely off topic. But I could find no better place to for it.
I am getting ready to change my sails from the winter sails to the summer sails. The reason is the winter sails are old and slow. Over the years I've noticed that the winter wind and the summer wind are different. Aside from being cold and wet, the winter wind seems to be stronger for the same knots. A 20 knt wind is still 20, but in winter the 20 knts seems to have more punch. I think this effect may have something to do with temperature and the number of molecules being pushed around. Any thoughts?
Quote: The wind and waver are always on the side of the ablest navigator.-Edward Gibbon, "The Decline and Fall of the Roman Empire"
luck66 is offline
post #2 of 6 Old 04-29-2014
The most female moderator
Donna_F's Avatar
Dock
Re: Wind and Sails
Luck, I'm going to move this into its own thread. It is a good discussion starter and I don't want it to get buried.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #3 of 6 Old 04-29-2014
Chastened
Ajax_MD's Avatar
Re: Winter vs. Summer Sails
Cold air is denser than warm air, so essentially more mass is pressing on your sails so yes, the punch is greater.
It's the equivalent of being hit with a 5 lb. mass at 20 kts vs being hit by a 2 lb. mass at 20 knots.
Automobile engines meter fuel differently during cold weather because the denser air changes the fuel/air ratio, as another example.
1981 Tartan 33 #168
Ajax_MD is offline
post #4 of 6 Old 04-29-2014
Bristol 45.5 - AiniA
I suspect it is like the difference between being hit by a 5 lb mass and and a 5.1 lb mass. I don't remember my details of Boyle's Law if that is the correct on, but the pressures are different, but not that different with the temps we are talking about.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #5 of 6 Old 04-29-2014
Minnesail's Avatar
I think the volume of a gas is linear with temperature when measured in degrees Kelvin. The Kelvin to Celsius conversion is 273º (thank you Wikipedia).
So if the temperature went from 273ºK (freezing) to 303ºK (a warm sunny afternoon) we do 273/303 = 0.9, so the air would only be 90% as as dense as it was at freezing.
Humidity might have more to do with it. Humid air is less dense than dry air (even though it doesn't feel that way) and warm summer air is going to be a lot more humid than dry winter air.
Catalina 22
on a starboard tack
Minnesail is offline
post #6 of 6 Old 04-29-2014
The density of air doesn't change that much with temprature.
Temp.....density (lbs/foot^3) Air - Temperature, Pressure and Density
30.........0.081
40.........0.080
50.........0.078
60.........0.076
70.........0.075
80.........0.074
90.........0.072
100.......0.071
My guess is that the difference is in your head more than in reality. Any difference here is probably equalled out by the lower absolute humidity of the colder air.
Greg
Stumble is offline
Summer sails now on NewsReader News Feeds 0 08-14-2013 01:30 PM
Reason #39 Why Summer is Better Than Winter bljones General Discussion (sailing related) 2 03-11-2011 09:02 PM
Sail in summer, program in winter avanti2001 Introduce Yourself 0 09-19-2010 05:12 PM
looking to crew winter 2008 or summer 2009 barefootbook Crew Wanted/Available 1 09-20-2008 08:44 PM
