Old 04-06-2006
FrankLanger is on a distinguished road
Washing the deck--is salt water o.k?
My fibreglass boat is moored at a coastal ocean slip without access to fresh water at the dock. Is it o.k. to wash the deck with salt water, or will this do more harm than good, by leaving salt crystals behind or promoting corrosion on the fittings? Any advice?
Thanks,
Frank.
Old 04-06-2006
yachtvalhalla's Avatar
Cruise-aholic
yachtvalhalla is on a distinguished road
Smile Try this cruiser's trick
As a liveaboard cruiser I often find the need to wash down the boat while hoarding our precious supply of fresh water. A trick for doing this is to put a dollop of vinegar in a bucket of salt water and rinse with this after you've done the washing. This eliminates the salt crystals that usually form after the salt water has dried. A quick wipe down of the stainless with a chamois helps prevent corrosion. This also works on the body as a final rinse .. but then when you apply suntan lotion you smell like salad dressing
Terry
"Does the song of the sea end at the shore or in the hearts of those who listen to it?" Kahlil Gibran
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Raw water flush with Salt Away flydude3 Gear & Maintenance 1 07-20-2005 10:37 AM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
Salt Water Cooling System failure. rclampitt Gear & Maintenance 4 07-28-2002 09:26 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
