Redoing wood in black...thoughts? - SailNet Community
 7Likes
post #1 of 13 Old 05-01-2014 Thread Starter
NewportNewbie's Avatar
I have very little wood on my deck, the 3 pieces of wood around the companionway I think I wanna do in black...ideas? Is there a black stain I can use then what do I use to protect it? Make sure it doesnt run?
Here is a pic of what it looks like now....
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 13 Old 05-01-2014
TQA
Bombay Explorer 44
TQA's Avatar
Re: Redoing wood in black...thoughts?
Varnish the wood first then paint it.
Then if you are a latter owner changes their mind you can strip the paint off.
TQA is offline
post #3 of 13 Old 05-01-2014
One of None
deniseO30's Avatar
sand/scrape and get it smooth.. fill the grain with thick varnish, keep filling and sanding it until it's smooth then paint it. Black paint doesn't last in the sun. Good luck!
My last project!
deniseO30 is offline
post #4 of 13 Old 05-01-2014
kd3pc's Avatar
minwax makes a polyurethane "ebony" stain that may fill the bill. I have used it and it holds up well. Not sure how long in the UV/Sun....but would look nice.
kd3pc is offline
post #5 of 13 Old 05-02-2014
islander bahama 24
newhaul's Avatar
my question is why black and the little bit you have would not take more than a couple hrs to varathane and bright looks so much better than paint. bet there are a couple kids in the marina that would be happy to do the job for a few bucks for burgers.
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #6 of 13 Old 05-02-2014
Old as Dirt!
svHyLyte's Avatar
You could, without much difficulty or cost, have the parts duplicated in white or black starboard by a local carpentry shop. Save the old parts and refinish them properly so they can be reinstalled later by the next owner should he/she wish to do so.
FWIW...
jimgo and ericb760 like this.
svHyLyte is offline
post #7 of 13 Old 05-02-2014
Master Mariner
capta's Avatar
If you keep the boat any where it gets hot and there's a lot of sun, painting the wood black will probably destroy it. It will absorb a great deal more heat and it will dry out and check pretty badly. If you live in the UK or Scandinavia, then it would probably be OK?
facebook.com/svskippingstone
Our Videos;
capta is offline
post #8 of 13 Old 05-02-2014
TomMaine's Avatar
I'd go with a gray enamel, say about the shade and matte gloss of your slotted toe rail. Black would be tough to make look right next to the plexi and the sun could make it fail earlier.
Tape it off, use a good underbody primer(two coats if it's weathered), good enamel paint in satin or semi-gloss, sand between coats.
That's not a lot of wood to deal with but it would be a job to replace those parts. Paint will preserve them nicely with the least maintenance. Should last for years.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is offline
post #9 of 13 Old 05-02-2014
JimsCAL's Avatar
If you do nothing, maybe it will mildew and turn black without doing anything.
Seriously, one of the worst ideas I've seen posted here.
JimsCAL is online now
post #10 of 13 Old 05-02-2014
Paint them with Linseed oil to darken them and protect the wood underneath.
christian.hess likes this.
sony2000 is offline
Black spots on the wood RossC32 Gear & Maintenance 12 08-24-2012 04:50 PM
Redoing shore power correctly jaschrumpf Electrical Systems 31 08-24-2012 02:15 PM
black piano wood? NewportNewbie Gear & Maintenance 17 08-25-2011 04:55 PM
redoing decks jeanfrancoissavard Gear & Maintenance 12 02-14-2010 01:02 PM
Redoing interior of boat for large crews and world sailing. pmarkt General Discussion (sailing related) 5 07-16-2007 10:49 PM
