simple question: shorepower - SailNet Community
post #1 of 13 Old 05-02-2014 Thread Starter
KejaGrad's Avatar
Hi.
I'm first-time owner (not first-time sailor) and my boat has just arrived at my marina. I'll be cleaning and working on it this weekend.
Just wondering: for shore power: do I simply plug one end of the cable into the shore side and the other to the boat and viola, I have power (i.e. 110 outlets)?
Thanks
KejaGrad is offline
post #2 of 13 Old 05-02-2014
Re: simple question: shorepower
Simple answer...Yes...assuming you have a standard shore power cord and standard shore power connections on both dock side and boat side.
Make a habit not to turn on your main boatside breaker (or shore side breaker) until the cord is plugged in. And...turn off one of the breakers before you unplug your cord as well.
Catalina 34
chuck53 is offline
post #3 of 13 Old 05-02-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
Power pylon/service?
Check
30 amp cord?
Check
30 amp plug on boat?
Check
Breaker on panel/shut-off sw/grd fault recept. on boat?
Other than that? Check condition and serviceability of the above.unplug all110v stuff aboard ta start with, IMHO;THEN check all receipts for GF and neutral ...ya never know
GTG
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #4 of 13 Old 05-02-2014
Delta-T's Avatar
Maybe, if you have an inverter or generator on board, you might have a transfer switch to switch for land power to other.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #5 of 13 Old 05-02-2014
Yes.... I always hook up my boat first before plugging in to the pedestal. Then flip breaker on.(if not on already) Not sure why. Something about holding onto a 30 amp cord on the back of my boat kind of gets me nervous.
Read this as well.
BoatUS – BoatTech – Safe Shorepower by Don Casey
benesailor is offline
post #6 of 13 Old 05-02-2014 Thread Starter
KejaGrad's Avatar
No inverter or such. 1978 C&C 27 MkIII. Marine breaker panel and battery switch. two batteries: house and crank. both connected and previous owner only charged via alternator.
boat is on the hard, so won't be running engine til next week.
I just want to be able to plug in some small appliances: lamp, fan, etc.
KejaGrad is offline
post #7 of 13 Old 05-02-2014
So your plugging into a 15-20 amp recepiticle (typical 120), Correct? Just make sure your cord length is not long. If it is make sure you are using the appropiately sized cord, BIG.
No problems.
post #8 of 13 Old 05-02-2014
Master Mariner
capta's Avatar
You gave no indication of size of the boat, amount of power required and whether you have the proper cord for the boat.
Whatever you do, you must insure that the shore power cord is appropriate for the onboard load. A 12 gauge extension cord is not going to run a battery charger, and air conditioner and the fridge. A 30 amp cord with proper ends will, and more.
If you are plugging a cord into the boat, you should also be certain that the boat has a proper 110 volt ac distribution panel, with main breakers and individual breakers for each circuit, and that they all work. I've seen panels where the bad breakers have been circumvented, leaving no protection on that circuit.
Hooking it all up for the first time, it wouldn't be a bad idea to be certain you have a functioning fire extinguisher handy.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #9 of 13 Old 05-02-2014
Group9's Avatar
Check
30 amp cord?
Check
Check
GTG
Yep, invest $5 in one of these do-hickeys. Easy way to check that.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #10 of 13 Old 05-02-2014
If I were you I'd at least inspect the 110V wiring. The receptacle where your shore power cord plugs in is a frequent failure point - the connectors corrode, then things start melting when you turn on your high-current stuff (heater, kettle, etc.). Had my shore power plug and receptacle both fuse together into one lump of melted plastic last year. Luckily I was on the boat at the time.
MarkSF is offline
One Simple Question - the movie billsull General Discussion (sailing related) 14 02-12-2015 01:49 PM
a simple question zengirl Announcements and Suggestions Box 5 03-02-2014 09:09 PM
Simple question, but still a question:keel repair eckcn17 Gear & Maintenance 9 03-16-2011 12:01 PM
Simple question Johnqboater Cruising & Liveaboard Forum 9 02-11-2011 01:00 PM
Very simple 4200 question radioguy Gear & Maintenance 5 08-21-2010 08:07 AM
