Painted prop - Page 2 - SailNet Community
 1Likes
post #11 of 27 Old 05-04-2014
s/v Tiger Lily
dvuyxx's Avatar
Re: Painted prop
I also use three thin coats of Petit Barnacle Barrier. It works fairly well for one-season application. Infinitely cheaper than Speed Prop. The prop should be brought down to bare metal and then rubbed down with acetone or MEK before applying.
Tempest likes this.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #12 of 27 Old 05-04-2014
I don't discuss my member
Fstbttms's Avatar
Re: Painted prop
Originally Posted by Sabreman View Post
Several Manufacturers make it, Interlux's version is called Trilux.
Interlux Trilux 33 does come in an aerosol spray, like Pettit Prop Coat Barnacle Barrier, but that's where the similarity ends. Barnacle Barrier is a hard, zinc-based product that cannot be used on fiberglass and wood while Trilux 33 is an ablative, copper-based paint with an additional anti slime biocide and requires a primer before being used on bare metals. The Pettit product requires no primer.
Fstbttms is offline
post #13 of 27 Old 05-04-2014
Re: Painted prop
Originally Posted by Fstbttms View Post
Barnacle Barrier is a hard, zinc-based product that cannot be used on fiberglass and wood while Trilux 33 ......
Care to elaborate that a bit?
/J
Jaramaz is offline
post #14 of 27 Old 05-04-2014
Fstbttms's Avatar
Re: Painted prop
Read the Product Data Sheet:
http://www.pettitpaint.com/fileshare...le-Barrier.pdf
Fstbttms is offline
post #15 of 27 Old 05-04-2014
Re: Painted prop - a (very) recent development
Well, without going into the deeper philosphical issues ...
Jaramaz is offline
post #16 of 27 Old 05-04-2014
Master Mariner
capta's Avatar
Re: Painted prop
Have there been a lot of "fiberglass and wood" props on the boats you've been cleaning lately?
Perhaps something is getting into your air supply?
facebook.com/svskippingstone
Our Videos;
capta is offline
post #17 of 27 Old 05-04-2014
Fstbttms's Avatar
Re: Painted prop
Trilux 33 is an anti fouling paint that is formulated to be used not only on running gear, but boat hulls as well. Barnacle Barrier is not. Had you taken the time to actually read the thread you would have understood that I was replying to a post that inferred that the two products were essentially the same, which they are not. I described the differences.
Fstbttms is offline
post #18 of 27 Old 05-04-2014
Fstbttms's Avatar
Whatever. Just telling you what the manufacturer says about the product. If you want to use it in a manner that runs contrary to the manufacturer's instructions, well, it's your dime and your prop.
Fstbttms is offline
post #19 of 27 Old 05-04-2014
Master Mariner
capta's Avatar
Re: Painted prop
Oooo. Somebody woke up cranky bears this morning.
Our Videos;
capta is offline
post #20 of 27 Old 05-04-2014
fallard's Avatar
Re: Painted prop
Originally Posted by StormBay View Post
The gray could be Interlux 2000. At our yard, they will often apply a barrier coat (to prevent contact between the bronze prop and copper in the antifouling) followed by 3 coats of regular non-ablative antifouling.
I checked with the Interlux customer service folks last year about Interlux 2000 insulating aluminum from the copper in a typical bottom paint. Their response was that Interlux 2000 does not effectively prevent galvanic action in this case and advised me not to use copper bottom paint.
fallard is offline
Cleaning Prop. & Replace w/ Folder or Feathering Prop. HighFly_27 General Discussion (sailing related) 17 09-02-2013 09:34 PM
Looking to have my boat painted kjzerr Gear & Maintenance 3 02-03-2013 08:52 PM
Painted combings? Cruiser2B Gear & Maintenance 7 05-02-2011 09:43 PM
Painted Deck mcrow33 Gear & Maintenance 5 02-20-2011 08:49 PM
Have you Painted your Sailboat yelnats69 Gear & Maintenance 2 06-11-2010 01:06 PM
