newbie mast light checking question - SailNet Community
post #1 of 11 Old 05-04-2014 Thread Starter
First spring commissioning. What do you guys do to check the mast lights? Just bring and hook up the battery? I guess thats the only option? but wanted to ask. I'd rather ask alot of questions and sound dumb but know what I am doing than not ask and just hope I may know what I am doing.
abrahamx is offline
post #2 of 11 Old 05-04-2014
Superior Sailor
Squidd's Avatar
Re: newbie mast light checking question
I winter with the mast down (indoor storage)
Before commissioning I hook a battery to the light(s) anchor, steaming and deck to check for operation as well as pull bulb and check sockets for corrosion
With mast up all you can do is hook up the battery and turn the switch...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is online now
post #3 of 11 Old 05-04-2014
Barquito
Barquito's Avatar
With the mast down you could use a multi-meter, and check the resistance through the wire. The wire and bulb should provide some resistance but is shouldn't be an open circuit. If any of the bulbs are LEDs, diodes only allow current in one direction.
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is offline
post #4 of 11 Old 05-04-2014
Use a voltmeter to check that 12V appears on the wires when you turn each switch on (also helps you to identify which wires are which); if you have a battery monitor or ammeter you should see the current go up if the bulb is on ( though it may be tough to register if you're using LEDs)
Finally if necessary a trip up the mast might be in order....
Faster is online now
post #5 of 11 Old 05-05-2014 Thread Starter
the mast is stored on a rack at the moment. Just lugging the battery over there seems like a pain.
abrahamx is offline
post #6 of 11 Old 05-05-2014
Sailor
Gladrags1's Avatar
Wait until it's dark and turn on the lights...
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #7 of 11 Old 05-05-2014
tommays's Avatar
A 9 volt battery will light all the bulbs and confirm they work
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
The Following User Says Thank You to tommays For This Useful Post:
Hudsonian (05-05-2014)
post #8 of 11 Old 05-05-2014
Dock
I picked up a cheap 12v lawn tractor battery to use for testing purposes. Enough amperage to make things noticeable, while still lasting more than a few minutes. And I can always recharge it for using later. It's not a 9v to carry, but it beats lugging a full size battery all over to test things.
1970 Islander Excalibur 26 - Retired
CharlzO is online now
post #9 of 11 Old 05-06-2014
Barquito
Barquito's Avatar
Drive the car over, and use jumper cables.
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is offline
post #10 of 11 Old 05-06-2014
ebs001's Avatar
You can use a multimeter on the ohms setting and check for continuity.
ebs001 is offline
Video from the top of the mast: repairing mast light wires jameswilson29 Gear & Maintenance 7 06-03-2013 04:45 PM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 04:11 PM
MacGregor Mast Question From A Newbie Micksan General Discussion (sailing related) 2 04-12-2009 02:17 PM
Catalina 22 mast light disconnect question andyjen Gear & Maintenance 12 03-04-2009 10:11 PM
Anchor Light - Newbie Question Fasteddy General Discussion (sailing related) 1 05-20-2002 11:50 AM
