Ablative vs. Hard Paints.... - Page 2 - SailNet Community
 2Likes
post #11 of 43 Old 05-04-2014
I don't discuss my member
Fstbttms's Avatar
Re: Ablative vs. Hard Paints....
Originally Posted by MedSailor View Post
I am planning on taking my boat out of the water for several months and I have petit trinidad hard paint on it. What's going to happen? Will it rust? Will it flake? Will it not work when I go back in? Will I sink?
My understanding is that Trinidad can withstand about 72 hours out of the water. Longer than that and you will have to repaint.
Fstbttms is offline
post #12 of 43 Old 05-04-2014
night0wl's Avatar
I live way upriver in brackish although mostly fresh water. Hard paint was awful for me. We were commissioned with Petit Trinidad SR on our bottom. First, didn't adhere very well to my iron keel, although that was likely the prep that was done by the dealer. Second, the paint nearly immediately started getting a slime layer on it. I had to have a diver once a month.
After my first haul, I stripped to bare bottom, epoxy coated, and then applied 2 layers of West Marine PCA Gold with Irgarol, which I hear is bulk repack of a major brand of ablative (it may be Petit). I love the stuff. $150 a gallon (friend has port supply account) and it lasts a loooong time. I have it dived only once every 8 weeks now and there is no fouling at all. When I use the boat, I get a clean bottom.
But again, its all dependent on your local conditions. Because I'm in almost fresh water, I dont worry about hard growth nearly as much as I worry about soft slime growth.
S/V Jendai
Beneteau 343
night0wl is offline
post #13 of 43 Old 05-04-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Check the Pettit web site.
Nice, succinct comparison on their site. Thanks.
Pettit paint comparison
MedSailor
MedSailor is offline
post #14 of 43 Old 05-04-2014
mitiempo's Avatar
Around here ablatives are very popular for cruisers. Many don't haul every year and our climate allows for year round sailing without need to avoid ice as they do in the east. This makes a multi-season ablative a good choice. We do not have any laws regarding in water scrubbing to worry about as does Washington State. As the chart states ablatives have a more consistent performance throughout their life. And if you do haul for any length of time their effectiveness doesn't diminish.
Pettit Horizons is the most popular choice in the store I work in and has just been lowered in price - by Pettit - to about $169 a gallon.
Here's the comparison:
Brian
mitiempo is offline
post #15 of 43 Old 05-04-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Hmmm.... makes me wonder in the comparison.....
What do the freighters use? Ablative or hard? The navy apparently uses ablative (based on the surplus paint I found recently).
MedSailor
post #16 of 43 Old 05-05-2014
pdqaltair's Avatar
[IMG]
In a recent post I put up this photo which everyone told me was ablative paint build up. Does this mean that ablative can still build up, but just not as bad or as fast? Does this photo represent 20+ years of buildup and it would be worse if it was hard paint?
MedSailor
The most common reason for ablative build-up is annual painting followed by little actual sailing during a short season. They simply don't wear it off. With a 2-year ablative and a bit more sailing, build-up will be nil. Generally by the time I paint, I can see the prior coat.
The best advice is always to ask around your area. Ask people who use their boats the same way you will.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #17 of 43 Old 05-05-2014
first sailed january 2008
northoceanbeach's Avatar
Wait. My boats in the same area as the OP(unless he is talking about his SF boat). It's been out of the water since December. I wasn't going to bottom paint it because the paint still so pretty new and looks good, but did it lose it's efficacy by being out of the water?
northoceanbeach is offline
post #18 of 43 Old 05-05-2014
no longer reading SailNet
Alex W's Avatar
What bottom paint is on your boat?
Alex W is offline
post #19 of 43 Old 05-05-2014
tommays's Avatar
New Paint Micron extra
Season one after power washing
Season two after power washing and ready for a quick scuffing and the next coat of paint
I life in a super high fouling area due to a out of spec sewer plant that discharges crazy amounts of barnacle larvae food
As such in the warmer times you must wipe off the larvae every two weeks or they will form hard growth no matter the paint used
The two power washings take a huge toll on the pint BUT you have to do it or the sting is horrible
After the first two year experiment I have gone to using enough paint for one season as it seems to perform better
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #20 of 43 Old 05-05-2014
Fstbttms's Avatar
Originally Posted by northoceanbeach View Post
My boats... been out of the water since December. I wasn't going to bottom paint it because the paint still so pretty new and looks good, but did it lose it's efficacy by being out of the water?
If its a hard paint, then the answer is likely yes.
Fstbttms is offline
bottom paint hard or ablative psherwin Gear & Maintenance 4 08-07-2011 08:53 AM
Are all epoxie paints good epoxie paints? SVTatia Gear & Maintenance 0 05-18-2011 05:04 PM
Using two different deck paints 2Sheets2Wind Gear & Maintenance 1 04-02-2010 12:24 PM
ablative or hard bottom paint? Patbarbeau Gear & Maintenance 11 07-29-2008 07:11 PM
