Ablative vs. Hard Paints.... - SailNet Community
 2Likes
post #1 of 43 Old 05-04-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Without getting into specialty types, there seem to be 2 main categories of paint:
1. Hard paint (I believe they are also called modified epoxy) which stay in place and leech copper to the surface to offend growth.
2. Ablatives, which allow critters to stick to them, but then peel away when scrubbed or when underway to allow the critters to fall off.
I've only ever used what came with the boat. The first boat was wood, and I was told that the hard paints couldn't be used (due to flexing of the hull?) and used ablatives. The current boat came with hard paint, so I continued that. I've had great success with both, but then again, I live in a low-growth area so that's probably the main reason for my success.
What are the pros and cons and applications for each? Is one better in the short or long term, or is one better than the other for frequent storage on the hard? How do you choose between the 2 broad categories?
MedSailor
MedSailor is offline
post #2 of 43 Old 05-04-2014
I don't discuss my member
Fstbttms's Avatar
Re: Ablative vs. Hard Paints....
Your descriptions of how a modified epoxy paint works is accurate. You're on the right track with your description of how an ablative works, but not quite spot-on. Ablatives work primarily because the surface of the paint "ablates", much like a bar of soap. As the paint moves through the water, the surface layer slowly wears away, exposing fresh biocide. This is not to say that no biocide is released while the boat is at rest- it is. But both types of paint are prone to some fouling and need to be cleaned periodically. Ablatives are no better at retarding this fouling (in most instances) than any other kind of paint.
Some pros and cons:
Hard paint pros- Durable, typically longer lived than ablatives, typically higher copper content. Cons- Successive layers of paint will at some point have to be removed, cannot be exposed to air for any length of time, limited color assortment.
Ablative pros- Can withstand exposure to air, will not build up like hard paints, wide color assortment. Cons- not particularly durable, low copper content, in-water cleaning restricted in some regions.
Fstbttms is offline
post #3 of 43 Old 05-04-2014
first sailed january 2008
northoceanbeach's Avatar
I believe in anacortes, in water cleaning of ablatives is prohibited. Not that I'm sure everyone doesn't anyways.
northoceanbeach is offline
post #4 of 43 Old 05-04-2014
Fstbttms's Avatar
That is a statewide regulation in Washington.
Fstbttms is offline
post #5 of 43 Old 05-04-2014
Senior Moment Member
SloopJonB's Avatar
Speaking as someone who once scraped & sanded decades of buildup off a 43' and who recently completed scraping & sanding a 30' boat to the gel-coat, I plan on never using anything but ablatives in future.
For any reason.
If in-water scrubbing becomes illegal, I'll willingly pay for a 1/2 lift to scrub it off rather than face that back breaking job ever again.
mitiempo likes this.
SloopJonB is offline
post #6 of 43 Old 05-04-2014
mitiempo's Avatar
Some pros and cons:
I agree with everything above except for the last line. Ablatives can have a high copper content.
Brian
mitiempo is offline
post #7 of 43 Old 05-04-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Some pros and cons:
In a recent post I put up this photo which everyone told me was ablative paint build up. Does this mean that ablative can still build up, but just not as bad or as fast? Does this photo represent 20+ years of buildup and it would be worse if it was hard paint?
I am planning on taking my boat out of the water for several months and I have petit trinidad hard paint on it. What's going to happen? Will it rust? Will it flake? Will it not work when I go back in? Will I sink?
MedSailor
post #8 of 43 Old 05-04-2014
mitiempo's Avatar
Most, if not all hard paint will lose its effectiveness if out of the water for a while.
Brian
mitiempo is offline
post #9 of 43 Old 05-04-2014
SloopJonB's Avatar
Check the Pettit web site.
MedSailor likes this.
post #10 of 43 Old 05-04-2014
Fstbttms's Avatar
Most ablative paints do not have what I consider to be a high copper content (say, 60% and above.) That said, you are correct, there are a few examples of the type that do claim high copper numbers, typically "hybrid" ablatives. Paints that share some properties of both hard and ablative paints.
Fstbttms is offline
bottom paint hard or ablative psherwin Gear & Maintenance 4 08-07-2011 09:53 AM
Are all epoxie paints good epoxie paints? SVTatia Gear & Maintenance 0 05-18-2011 06:04 PM
Using two different deck paints 2Sheets2Wind Gear & Maintenance 1 04-02-2010 01:24 PM
ablative or hard bottom paint? Patbarbeau Gear & Maintenance 11 07-29-2008 08:11 PM
