I think I stuffed my furler. What do you think? - Page 2 - SailNet Community
 5Likes
post #11 of 15 Old 05-06-2014 Thread Starter
Re: I think I stuffed my furler. What do you think?
Thanks everyone. Spin and jib halyards backing up forestay now. Don't tell anyone, but the standing rigging is 30 years old! (I've only had her 18 months) Time to spend a few b.o.a.t. dollars on replacing that.
And yes, I will take the mast down at the same time, repaint it, fix the masthead light and wind instrument, replace the lights with LEDs, rerun the cables and stop them from clanking inside the mast! Seems I won't be sailing for a little while.
WeedySeaDragon is offline
post #12 of 15 Old 05-06-2014
No more curry buffets
Ritchard's Avatar
If you're starting a campaign of replacing the standing rigging, you might consider doing it with superline instead of wire rope - except perhaps your forestay. I plan to make this change over the next couple of seasons, my wire rope is getting pretty long in the tooth. Lots of info on this on the Colligo marine website. Colligo Marine - Rigging reduced to its elegant essentials. - Colligo Marine - Synthetic Rigging
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
The Following User Says Thank You to Ritchard For This Useful Post:
WeedySeaDragon (05-08-2014)
post #13 of 15 Old 10-07-2014 Thread Starter
Thanks Ritchard. I looked into it but decided to stay with wire. I'll finish my blog post on the re-rig and post it here. Managed to get keep the old furler (thank goodness - that would have added quite an expense).
MarkofSeaLife likes this.
post #14 of 15 Old 10-07-2014
celenoglu's Avatar
The angle between the halyard and the forestay should be more than 7 degrees, otherwise the halyard wounds around the forestay and the forestay breaks after some time. You should attach a block to increase this angle and replace the forestay.
celenoglu is offline
post #15 of 15 Old 10-20-2014 Thread Starter
Thanks celenoglu but I'm not sure that's the case with my old school setup. I think with this old furler the halyard is integral to the furler head and returns back down the furler extrusion and is secured to the body of the furler; so it rotates with the furler.
Here's the link to my write up of the re-rig fwiw: The Big Re-rig: Part 2 | Adventures in Bob
Tags
furler
What's this on the furler? Dave_E Gear & Maintenance 5 11-26-2013 10:50 AM
Which Furler? sdinger General Discussion (sailing related) 7 03-09-2012 08:50 PM
My mast is stuffed full of foam? afrinus Gear & Maintenance 7 09-19-2011 05:33 PM
A Furler? jetdrvr393 Gear & Maintenance 6 11-10-2009 09:56 PM
Furler Questions rayncyn51 Gear & Maintenance 20 08-20-2009 01:56 PM
