I think I stuffed my furler. What do you think? - SailNet Community
 5Likes
post #1 of 15 Old 05-05-2014 Thread Starter
I think I screwed my furler in yesterdays strong winds. I partially unfurled it, sailed a bit, then furled it back up when it had some tension in the sail (not flogging).
Anyone with any experience of this type of furler and problem?
The furler is resisting turning as though it has a spring in it and very noisy. See
vid
Here is a pic of what's inside through 1cm hole in drum. The image looks as though there are wires spiralling up over the forestay, wound in the opposite direction.
I would be guessing that I've messed these up by furling the sail whilst the furler was not straight (due to strong winds on partially furled sail under pressure).
Any thoughts?
WeedySeaDragon is offline
post #2 of 15 Old 05-05-2014
Sailor
Gladrags1's Avatar
Re: I think I stuffed my furler. What do you think?
Wonder if that is a ring cotter that is unwound. Can you slide the drum up to see what's inside?
Tod
Mandolin, Bayfield 36 sailing out of Rock Creek.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 15 Old 05-05-2014
smj
Appears a few of the wires from the forestay have broken at the swage fitting?
killarney_sailor likes this.
smj is offline
The Following User Says Thank You to smj For This Useful Post:
WeedySeaDragon (05-05-2014)
post #4 of 15 Old 05-05-2014
Sailor
Gladrags1's Avatar
I was wondering that myself. If that is the case, you cannot sail the boat until repaired or you may lose your mast. Just in case, take a spinnaker halyard and attach it to a fitting in the bow and tension it to support the mast until you can check it out and make repairs. If you don't have a spinnaker halyard, lower the jib, use the jib halyard.
Tod
trantor12020 and jimgo like this.
Mandolin
Bayfield 36
The Following User Says Thank You to Gladrags1 For This Useful Post:
post #5 of 15 Old 05-05-2014 Thread Starter
You may be right smj (and gladrags1); it does look suspiciously like that, doesn't it. That would also explain the 'spring-like' effect if a couple of strands have come loose and have become wound loosely between forestay and furler.
Looks like I'll be replacing the standing rigging.
Thanks Gladrags - will do.
post #6 of 15 Old 05-05-2014
Group9's Avatar
That what scares me about my roller furling and not being able to see the condition of the stay underneath it. At least you know.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #7 of 15 Old 05-05-2014
Bristol 45.5 - AiniA
I don't think you need to worry about the forestay breaking at the dock, there are still lots of wires that are ok. You can replace your standing rigging at the dock, piece by piece but it might be a good idea to take the mast down and check everything if it has not been down for some time.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #8 of 15 Old 05-05-2014
Delta-T's Avatar
Did you look to see if you have halyard rap?
MarkofSeaLife likes this.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #9 of 15 Old 05-05-2014
christian.hess's Avatar
that is a very very RUSTY forestay that has been "unwound" slightly...there are a couple of wires that have snapped...they are probably adding to the noise you feel and if unwound enough might be what the resistance is about
also to note is its swaged and not mechanical like most furlers recomend these days
get a new one made with prefferably a mechanical terminal in the lower connection, a toggle too, so that you can always be able to access and check the conditions of the wires on the bottom which is the one that takes the most abuse
stays unwinding are common failure points on furlers the reason being its very easy to really twist and warp the forestay a lot with a badly maintained furler that and unfurling a jammed sail is almost always the best way to snap wires...and unlay a forestay
good luck
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #10 of 15 Old 05-05-2014
I found the correct term but only 1/8 in "rotational resistant" wire rope. You could ask someone with more experience if it would have any applications for a forstay.
Zen is a matter of recognizing reality.
desert rat is offline
Tags
furler
What's this on the furler? Dave_E Gear & Maintenance 5 11-26-2013 09:50 AM
Which Furler? sdinger General Discussion (sailing related) 7 03-09-2012 07:50 PM
My mast is stuffed full of foam? afrinus Gear & Maintenance 7 09-19-2011 04:33 PM
A Furler? jetdrvr393 Gear & Maintenance 6 11-10-2009 08:56 PM
Furler Questions rayncyn51 Gear & Maintenance 20 08-20-2009 12:56 PM
