So I'm modifying this 22 foot mast to be used on my catamaran (Solcat 18) because the original mast is too big and heavy for one person to raise (I'm almost always sailing solo). This smaller mast cast came from Islands 17 dinghy and had one set of spreaders which are fairly swept back. The original spreaders were fairly lightweight aluminum pipe, there was only one left, and in poor shape, so I have to make new ones.
My questions are:
Is it OK to get rid of the spreaders?
My gut feeling is 'no'. But they are swept back so much that going downwind they will be seriously interfering with the sail, likely to the point of rubbing the crap out of it. So the next question is:
Should I change the spreader sweep, and to what extent?
Because my cat has a 1.5 feet wider beam than the boat from which the mast came, I have to make the spreaders longer (which makes them interfere with the sail that much more). I'm making the spreaders out of aluminum rod, about the same diameter as the original aluminum pipe. I have the rods already so it is not a matter of cost, but maybe that is not the best material? So the last question:
Is aluminum rod a good choice for these spreaders?
Considering the sail area of the Islands 17 (135 SF) compare with the Sol Cat (220 SF) changing the rig will dramatically reduce the performance capability of the Sol Cat (by about 39%). It would be wiser for you to learn how to use a gin-pole to assist your mast raising which, with that could be accomplished with a relatively small 2 or 3 part tackle.
When I had my solcat 18, and I was by myself I found the easiest way to rig the mast was this. Take the cat off the trailer and put it on the beach. With a 2x4 cut to the right length at your feet, flip the cat on its side 90 degrees and wedge in 2x4. Walk around other side and lift mast into place using its weight to wedge it onto the mast base. Then connect your wires. I'm 6'2" tall and could easily reach the upper shrouds to connect the pins but it might be different for you.
As was said earlier a gin pole would be the "proper" solution to be used while on the trailer. It makes it handier as there isn't always a nice soft beach nearby. I just never spent the time to make one when I owned my cat. You could make one out of wood with a few relatively cheap fittings to attach it to the mast. No need for stainless as it'd just be used for rigging the mast then stored on the trailer.
I'd stick with the original mast as well before switching to a different one. The other mast may be built lighter but it'd might not be up the task strength wise for the cat. Keep in mind the solcats were designed for racing/ performance. So if they have a heavy mast it's probably for a reason.
Or maybe that reason was just to simplify the rig and not have spreaders... Either way I'd not use solid rod for the spreaders, considering you want to keep the weight aloft to a minimum. Whats the saying every pound aloft is like loosing 10lb off the keel. (Then again I guess you don't have a keel to worry about ) I'd use a pipe before solid rod.
I'm planning to use smaller sails, of course, and I'm not that concerned with speed. The smaller mast is SO MUCH easier to rig by myself, so it is very tempting to modify. I am sailing on inland lakes so beach rigging is not an option. I have to launch from the trailer. I would love to try the idea of flipping the cat on the side and rigging the mast that way, but that is not an option right now. I'm not worried about the weight gain from solid spreaders as the new mast is a lot lighter. My primary concern is rig strength (do not want to get dismasted in a blow) and mast stability. And of course I don't want to make a hole in the main by one of those spreaders.
I was thinking long and hard about building a gin pole for the original mast, but raising mast that way is still a 2 man operation. The original mast is about 4.5 feet longer than the mast I want to use. And I can raise that mast by myself in just a couple of minutes.
yeah I dont see where you gain any wieght by going sold bar versus pipe, for one you are using a shorter lighter mast...so its a very hard argument against what you already have not to mention cost savings
can you find any pics of the 2 boats for example looking at the mast from the stern, then a real life profile pic?
that way you can compare stay angles, forestay height and angle and if and where you can tie in your spreaders and at what angle ideally
Brion Toss's book, The Rigger's Apprentice, has the kind of info on mast/spreader/shroud angle geometry you are asking about. It's very straightforward and will help you to minimize the guesswork on something that is pretty crucial to your boat.
John V.
Keep the bigger mast and instal a mast hinge and gin pole. I can put up the rig on my Corsair 750 in about 30 minutes solo.
If you go with a smaller mast, you have more issues than just spreader angles. You also need to address the extra righting moment of the multihull. Figure the RM on the cat is probably 10 times what the dinghy was, which means you need a much stronger rig to carry the same sail area since the boat won't heel to dump air.
This is doable, though I wouldn't advise it, but you need to run the numbers to make sure the new mast can handle the load.
Good point, something I thought about. I was planning to dump air through a more conservative sail trim. I am using the same size shrouds as the big mast had, so they should be strong enough. Most of the time I sail in relatively light air anyway. There are some strong gusts now and then but these can be managed by spilling the air from the main. My jib is rather small.
What would be the initial signs that the rig is not strong enough for the amount of sail I carry? Spreaders bending?
The purpose of spreaders is to reduce the compression load on the mast by widening the angle of the stays to the masthead. Any cat is wider than a mono so simply running the shrouds out to the hulls should give you plenty of angle without spreaders.
I just got an answer to one of my questions, regarding the spreaders possibly getting in the way of sail when going down wind: their design allows them to pivot forward with the sail thus creating much less chaff.
But I just found out that the sail track on the mast is pinched half way up, not allowing the slugs to pass. Another little project for tomorrow afternoon.
Thanks for asking.
The mast is up, looking good and solid. Ordered a main sail for it (from a 505 class dinghy) which I am expecting to receive next Monday, and should be ready to sail next week. The jib from the original rig will work as I have moved the stays about 18" up (it is still a fractional rig, just not that extreme).
I have hardly spent much money on this project, mostly a few ss screws and bolts, and $150 for the smaller sail, which I can use on my 5.5m Mirage (it is a bit shorter than my regular main), so if it does not work I will not be too upset.
Don't do it! The boat will be ruined. A solcat without a rotating mast is an abomination. Heck, I raised the mast on my Stiletto 27 solo (at least 3x the weight) with the winch and gin pole.
I had a beach cat for years, always rigging solo.
*build a wishbone gin pole.
* take the trap lines to the beam ends to stop sway.
* add a large eye to the end of the forstay, such that it hangs below the pin.
* Use the trailor winch. Place a clamp on the cable tht engages the gin pole such that the gin pole falls away as the mast comes up.
Easy. I could stop with it half way up an eat lunch if I wanted to. I could do it on less than level surfaces, or with a good wind.
So I have been sailing my cat with a smaller mast for a while now (on an inland lake) and I'm happy to report that everything works just fine, no rig failure of any kind (knock on wood). I had it out in 20 mph winds (sustained). My cat is still by far the fastest sailboat around, sometimes going as fast as some stink potters. Love it, love it, loooooooove it!
The mast is super easy to raise just for one person, and the mainsail from the 505 class dinghy works great. The top of the mast bends a little under the heavy load of beam reach but that is just normal and the mast springs back. Tacking is a bit tricky (as typical for cats) and I use a backwinded jib to complete the tack.
The cat seems to be very stable in general but on a beam reach at 20mph wind it took both of us sitting on the weather side hull to keep the hull from coming out of water, which leads me to believe that I have plenty of canvass on my cat.
I had to open my friggin' mouth and brag about my scaled down rig working great... :/
Today I was sailing in strong gusty winds (30mph+) and I have bent my mast. About 3" off center, smack in the middle. But at least it was one heck of a ride.
Anybody has an old mast for cheap?
Related Threads
1.7M posts
173.8K members
Since 1990
