Mast spreaders function question - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree12Likes
Old 05-05-2014
krisscross's Avatar
krisscross is on a distinguished road
So I'm modifying this 22 foot mast to be used on my catamaran (Solcat 18) because the original mast is too big and heavy for one person to raise (I'm almost always sailing solo). This smaller mast cast came from Islands 17 dinghy and had one set of spreaders which are fairly swept back. The original spreaders were fairly lightweight aluminum pipe, there was only one left, and in poor shape, so I have to make new ones.
My questions are:
Is it OK to get rid of the spreaders?
My gut feeling is 'no'. But they are swept back so much that going downwind they will be seriously interfering with the sail, likely to the point of rubbing the crap out of it. So the next question is:
Should I change the spreader sweep, and to what extent?
Because my cat has a 1.5 feet wider beam than the boat from which the mast came, I have to make the spreaders longer (which makes them interfere with the sail that much more). I'm making the spreaders out of aluminum rod, about the same diameter as the original aluminum pipe. I have the rods already so it is not a matter of cost, but maybe that is not the best material? So the last question:
Is aluminum rod a good choice for these spreaders?
Thanks for your help!
Plato
  #2
Old 05-05-2014
new dad!
christian.hess is on a distinguished road
Re: Mast spreaders function question
yeah good choice on material but some pics or diagrams would be great...
I dont think you will HAVE to make the spreaders that much longer...
is it not possible to modify the sweep of the spreaders?
1973 Islander 36 "resto" ALMOST there, and ready to SAIL!
  #3
Old 05-05-2014
krisscross's Avatar
Yes, it is possible to modify the sweep and placement of the spreaders, I'm just not sure what would be a best way to do it. The original mast and boat here: ISLANDS 17 sailboat specifications and details on sailboatdata.com
This is the boat I'm modifying:
SOL CAT 18 sailboat specifications and details on sailboatdata.com
I could move them up and change the angle a bit to make it work with the geometry of the rig. That is my gut feeling about it.
Plato
  #4
Old 05-05-2014
new dad!
any real life pics?
I can see the stays are angle back quote a bit from the mast on the 17,
what I would do is try to emulate the angles found on that boat since your are using that mast...with maybe slightly less sweep...
does the forestay attachment look the same, or better put will the angle off the luff be the same?
try to keep the same gemoetries or it might put too much strain in places that mast wasnt designed to
for exampe is the spreader height remaining the same?
krisscross likes this.
  #5
Old 05-05-2014
new dad!
the cat has no spreaders I see now my bad...but I see the angle of the stays is similar if not more on the cat...just from looking at the diagrams...
mast height slightly less with the new mast right? how much shorter?(this could be important for going spreaderless, just maybe)
  #6
Old 05-05-2014
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Considering the sail area of the Islands 17 (135 SF) compare with the Sol Cat (220 SF) changing the rig will dramatically reduce the performance capability of the Sol Cat (by about 39%). It would be wiser for you to learn how to use a gin-pole to assist your mast raising which, with that could be accomplished with a relatively small 2 or 3 part tackle.
  #7
Old 05-05-2014
appick is on a distinguished road
When I had my solcat 18, and I was by myself I found the easiest way to rig the mast was this. Take the cat off the trailer and put it on the beach. With a 2x4 cut to the right length at your feet, flip the cat on its side 90 degrees and wedge in 2x4. Walk around other side and lift mast into place using its weight to wedge it onto the mast base. Then connect your wires. I'm 6'2" tall and could easily reach the upper shrouds to connect the pins but it might be different for you.
As was said earlier a gin pole would be the "proper" solution to be used while on the trailer. It makes it handier as there isn't always a nice soft beach nearby. I just never spent the time to make one when I owned my cat. You could make one out of wood with a few relatively cheap fittings to attach it to the mast. No need for stainless as it'd just be used for rigging the mast then stored on the trailer.
  #8
Old 05-05-2014
I'd stick with the original mast as well before switching to a different one. The other mast may be built lighter but it'd might not be up the task strength wise for the cat. Keep in mind the solcats were designed for racing/ performance. So if they have a heavy mast it's probably for a reason.
Or maybe that reason was just to simplify the rig and not have spreaders... Either way I'd not use solid rod for the spreaders, considering you want to keep the weight aloft to a minimum. Whats the saying every pound aloft is like loosing 10lb off the keel. (Then again I guess you don't have a keel to worry about ) I'd use a pipe before solid rod.
  #9
Old 05-05-2014
new dad!
I beleive kriss cross already considered that on another thread...a while back
he has this mast and is asking about this mast
I remember comenting on that other thread too...there are benefits to a shorter, lighter mast for a solo cat sailor...
cheers
  #10
Old 05-05-2014
krisscross's Avatar
I'm planning to use smaller sails, of course, and I'm not that concerned with speed. The smaller mast is SO MUCH easier to rig by myself, so it is very tempting to modify. I am sailing on inland lakes so beach rigging is not an option. I have to launch from the trailer. I would love to try the idea of flipping the cat on the side and rigging the mast that way, but that is not an option right now. I'm not worried about the weight gain from solid spreaders as the new mast is a lot lighter. My primary concern is rig strength (do not want to get dismasted in a blow) and mast stability. And of course I don't want to make a hole in the main by one of those spreaders.
Plato
You may post attachments
You may edit your posts
repairing wooden spreaders with mast steps installed dan8152 Gear & Maintenance 13 03-16-2014 05:14 PM
A C&C question? on spreaders ltgoshen Gear & Maintenance 13 10-29-2012 12:53 AM
1987 Beneteau 305 First (dual spreaders) mast adjustment waterboyllp Boat Review and Purchase Forum 6 12-01-2009 12:43 PM
Mast spreaders TrevorHeath Gear & Maintenance 6 12-11-2007 09:57 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
