Appropriate mast bend? - SailNet Community
 4Likes
  • 2 Post By pdqaltair
  • 1 Post By Faster
  • 1 Post By tommays
post #1 of 8 Old 05-05-2014 Thread Starter
Hi All,
I read through Seldon's mast tuning guide, as well as some other less formal guides when tuning my mast recently, and I got all the shrouds/stays tensioned correctly. this being my first time tuning a mast, however, I'm second guessing myself. The mast is in column. Is this amount of mast bend appropriate?
The boat is a Beneteau 361.
Any input is greatly appreciated.
bshock is offline
post #2 of 8 Old 05-05-2014
ASA and PSIA Instructor
Re: Appropriate mast bend?
Looks reasonable to me, what does the manual say about pre-bend, 8" or something like that? I assume the backstay was not tensioned for the picture?
sailingfool is offline
post #3 of 8 Old 05-05-2014
krisscross's Avatar
Forgive my ignorance, but is mast rake (mast raked back just a bit) accomplishing basically the same thing?
Plato
krisscross is online now
post #4 of 8 Old 05-05-2014
pdqaltair's Avatar
No. When the mast bends the center of the luff moves forward, pulling sail cloth from the sail and making it flatter. An obvious corollary is that any sail to be used with a pre-bent or bendy mast is cut with this in mind.
Simplified, but the point is mast bend affects fullness, while rake primarily affects COE (also lift if extreme).
krisscross and christian.hess like this.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
The Following User Says Thank You to pdqaltair For This Useful Post:
Multihullgirl (05-05-2014)
post #5 of 8 Old 05-05-2014
Mast rake will primarily affect your rig balance and the amount of weather helm you may or may not have since it moves your CE fore and aft. Mast bend generally is set to match the luff curve of your mainsail so that the draft position is optimal for the cut of the sail. More bend pulls material forward and 'flattens' the sail somewhat. A sail meant for significant prebend will have a very full shape set up a dead straight mast.
krisscross likes this.
Faster is offline
post #6 of 8 Old 05-05-2014
tommays's Avatar
The exact Pre-bend really depends on how the sail was cut as there are some pretty big difference's from one sailmaker to another
It is why there are 27 tuning guides for the J24 which vary from perfectly straight to really bent
christian.hess likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 8 Old 05-06-2014 Thread Starter
Thanks guys for the insight.
bshock is offline
post #8 of 8 Old 05-06-2014
Try the mast bend where you have it and see if you like how the sail sets. It looks like you have about 3~4" of bend or half a section. You're limited with a swept rig as to how much bend you can achieve.
Shockwave is offline
Mast bend? AirborneSF C & C 8 04-09-2013 02:32 PM
mast bend Piratesoul Irwin 0 07-20-2008 06:20 AM
N30 mast bend RussLeighton Newport 2 06-06-2008 08:21 AM
Islander 28 mast bend remlap Islander 2 04-24-2008 11:39 PM
Mast Bend offline2004 Gear & Maintenance 7 02-17-2006 10:50 AM
