Outhaul repair/replacement - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 05-28-2014 Thread Starter
L124C's Avatar
Re: Outhaul repair/replacement
Received the new sheaves from Ed at ZEPHYRWERKS. He was a pleasure to work with. Getting the Amsteel line today and should have the old system back together this week, reviving it for less than $100. It was tempting to go with a new system, however, this was a lot less expensive, didn't require drilling additional holes in the boom and as funky as it is, IT WORKS!
As always....thanks for the help!
L124C is offline
post #12 of 13 Old 05-29-2014 Thread Starter
L124C's Avatar
First lesson re: Amsteel 3/16.
Amsteel is larger than the 3/16 wire rope it replaced. Hence, it won't fit through the old hardware. Purchased some 1/8 today. We'll see how that works! Just need to come up with some type of fid small enough to work with it. Apparently, coat hangers or a ball point pen cartridge, or pulling it with guitar wire work.
L124C is offline
post #13 of 13 Old 05-29-2014
WoobaGooba's Avatar
Good tips for splicing small dyneema ...
Splicing 3mm spectra - Fix It Anarchy - Sailing Anarchy Forums
WoobaGooba is offline
Tags
out haul , outhaul , yankee 30
Holding tank repair/replacement Paige, Too Gear & Maintenance 2 12-04-2012 07:25 PM
Keel Bolts Repair/replacement chartscharts Gear & Maintenance 11 08-07-2006 03:53 PM
Head Sail repair/replacement wsutton Gear & Maintenance 0 07-12-2006 08:01 AM
Head Sail repair/replacement wsutton Gear & Maintenance 0 07-12-2006 08:00 AM
Rudder replacement/repair namaste04 Gear & Maintenance 4 05-28-2003 07:47 AM
