Topping lift loads? - Page 2 - SailNet Community
 12Likes
post #11 of 26 Old 05-06-2014 Thread Starter
Frozen Member
AlaskaMC's Avatar
Re: Topping lift loads?
Thanks everyone! This is just what I was thinking but wanted to be sure. I will have 1/4'' line with a 2000lb breaking strength, harken block with a 400lb + working load at both ends and a jammer to match so I think all will be well.
AlaskaMC is offline
post #12 of 26 Old 05-06-2014
Barquito
Barquito's Avatar
Captianforce - I LOVE the yo-yo. Post this idea on the 'Low Buck Projects' thread! Yo-yo's on a sailboat, that has panache.
AlaskaMC likes this.
Valiant 32
Barquito is online now
post #13 of 26 Old 05-07-2014
no longer reading SailNet
Alex W's Avatar
Originally Posted by IStream View Post
Alex, I assume you meant to say that your topping lift is left adjusted slightly longer than the leech, not your main sheet, correct? If not, could you clarify?
That is correct, sorry about the confusion.
I made my topping lift extremely light and it is carefully adjusted so that I don't have to touch it on the vast majority of my sails. It is light so that it blows out of the way of the leech when sailing. It is carefully adjusted to be just longer than the leech so that it is short enough to keep the boat's boom from touching the dodger when the sail is lowered, but long enough to avoid changing the sail shape.
Alex W is offline
post #14 of 26 Old 05-07-2014
On my former 25' boat, I only used the topping lift to briefly keep the boom from falling into the cockpit while raising and lowering the sail, and when reefing. Except for those brief moments, I had the pig tail hooked up. I unhooked the pig tail just prior to raising the sail and immediately after lowering it. My crew knew they couldn't lean on the boom during those few seconds, and steadied themselves elsewhere, such as at the mast or a grab rail. Because it was so briefly used, I used the lightest nylon line possible. I think it was 1/8 inch nylon. It was enough to do the job required of it, and, if I ever forgot to ease the topping lift after the sail was up, it stretched so easily that it wasn't a problem. If my boat didn't have a pig tail or boom crutch or similar device, then I'd want a light, but strong, non-stretching line.
I'm not an advocate of the "oversized line" theory. I generally prefer to use the size of line that is just right for the task, and no more. Oversized lines often don't run freely through the blocks, and they are often too thick or too heavy to work well. I'd rather have it work properly, and, if I wear it out, then replace it, and use the old line for lashing things or other uses.
christian.hess likes this.
Sailormon6 is offline
post #15 of 26 Old 05-07-2014
christian.hess's Avatar
with the newer tech lines and stronger lines per size if you will Im a great fan pf going one size under...
the amount of friction lost and ease of sheeting in, hauling, pulling etc...is significantly reduced
for my boat for example its in the builders forums, that its recommended to downsize both to save some cost but for these reasons too
especially when going from wire rope halyards to all rope...
there is nothing worse in my mind than chubby lines stuffed in blocks...so clumsy...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #16 of 26 Old 05-08-2014
I weigh 230, the Admiral sent me over the side while securing the mainsail, hung on to the boom until I could get her to turn the boat back into the wind. Sure glad the topping lift held. ( I now have an electric tiller pilot)
jimgo likes this.
H and E is offline
post #17 of 26 Old 05-08-2014
Asleep at the wheel
jimgo's Avatar
H and E, thanks for that story. I think it may be time for me to buy some dyneema for my topping lift.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #18 of 26 Old 05-08-2014
Master Mariner
capta's Avatar
Unless you have a boom crutch or a hard vang, you are going to put some tremendous loads on your topping lift, to keep the boom from swinging around, when NOT sailing. Your main sheet is a larger diameter line and on a multi-purchase block and tackle system which you are tightening against the lowly topping lift. Nuff said?
facebook.com/svskippingstone
Our Videos;
capta is online now
post #19 of 26 Old 05-08-2014
it has worked for me quote well
in bigger boats you just tie up some preventers to each side
simple enough
my topping lift is one size smaller than my main sheet
post #20 of 26 Old 05-08-2014
Alex W's Avatar
Or unless you tie off the main halyard to the end of the boom when the mainsail is put away. That keeps it away from the boom and supports the end of the boom.
Alex W is offline
Topping Lift sehopkins Learning to Sail 16 05-04-2015 06:56 AM
Topping lift? themotorman General Discussion (sailing related) 13 11-20-2009 11:34 AM
Topping lift denby General Discussion (sailing related) 82 05-16-2008 09:18 AM
topping lift wumhenry Learning to Sail 24 08-04-2007 02:19 PM
Topping Lift jkrug Gear & Maintenance 18 05-04-2007 09:07 PM
