Topping lift loads? - Page 3 - SailNet Community
 12Likes
post #21 of 26 Old 05-08-2014
Master Mariner
capta's Avatar
Re: Topping lift loads?
Originally Posted by Alex W View Post
Or unless you tie off the main halyard to the end of the boom when the mainsail is put away. That keeps it away from the boom and supports the end of the boom.
OK then Alex, I'll just drop my roller furling main every day and do that from now on. Now why didn't I think of that? Such a simple solution, too.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #22 of 26 Old 05-08-2014
davidpm's Avatar
The following is a sceniaro where a strong topping lift might be a good idea.
Your sail is down, the mail halyard is at the mast and you are motoring and run aground.
You let three or four of your heaviest crew hang on the boom as you swing it outboard as you try to heel the boat enough for the keel to clear the mud to get free.
A 1,000 pounds maybe.
I always think of the topping lift as an emergency halyard anyway.
But in truth on most smaller boat most lines are sized for hand comfort rather than for strength.
davidpm is offline
post #23 of 26 Old 05-09-2014
no longer reading SailNet
Alex W's Avatar
The OP has a MacGregor 25. It never occured to me that a boat that small would have a furling main (and I don't believe that it does). I'm offering him advice.
There are very different ways of rigging a small boat vs a larger one. The loads are extremely different too. A topping lift on a small boat does not need to be complex or extremely beefy. A bit of 2000lb breaking load 1/8" dyneema does the job better than just about anything else.
Tempest and christian.hess like this.
Alex W is offline
post #24 of 26 Old 05-09-2014
Master Mariner
capta's Avatar
But the load on even a small boat topping lift is a lot more than some would expect. If dropping the main in a lousy sea, you'd want to tighten up the boom with the sheet to keep the boom from swinging around when you are on the cabin top furling the sail, right? That's a single line topping lift versus a multi-purchase main sheet (usually of a greater size, too), which was my point. Later the halyard may be moved to the boom end, but I for one am not going to do that until secure at anchor or in the slip, just in case.
Our Videos;
capta is offline
post #25 of 26 Old 05-09-2014
christian.hess's Avatar
yeah thats why Im a fan of those pig tail thingies...I wouldnt change anything on said boat but if the op wants a topping lift thats cool too
like I said one size down or 2 for the topping lift compared to the MAIN sheet is a good conservative solution
or one size down from halyard...
or dyneema
or wire
or you can make one of those classic boom stands like on old boats
or add a boom kicker
or make a hard dodger and tie the boom to that
the list is endless!
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #26 of 26 Old 05-09-2014
Alex W's Avatar
The main sheet on such a boat has a 3:1 or 4:1 tackle and an average person who isn't struggling will be able to get about 200lbs of downward pressure on the boom (using the standard rule of thumb of pulling 50lbs on an average sailboat line).
The lightest setup mentioned in this thread was using a block that was rated to about 500lbs and line rated to 2000lbs. That is not too light for these conditions.
Alex W is offline
Topping Lift sehopkins Learning to Sail 16 05-04-2015 06:56 AM
Topping lift? themotorman General Discussion (sailing related) 13 11-20-2009 11:34 AM
Topping lift denby General Discussion (sailing related) 82 05-16-2008 09:18 AM
topping lift wumhenry Learning to Sail 24 08-04-2007 02:19 PM
Topping Lift jkrug Gear & Maintenance 18 05-04-2007 09:07 PM
