Best Boat Hook? - Page 4 - SailNet Community
 6Likes
post #31 of 36 Old 05-11-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Re: Best Boat Hook?
Originally Posted by Group9 View Post
I've never used one as a spinnaker pole, but I had a home made wooden boat hook (with a bronze end), that I made extra long, that I used as a whisker pole for years with no drama. And, the best thing was, it floated!
Yup, I did this too with the wooden one I made. Used it on the genoa in light winds, never in heavy air. Worked fine.
MedSailor
MedSailor is offline
post #32 of 36 Old 05-11-2014
Once known as Hartley18
Classic30's Avatar
Dock
Re: Best Boat Hook?
Done that with mine too - plenty of times - but:
Originally Posted by davidpm View Post
I've learned that they don't do double duty as a Spinnaker pole even in very light wind with just the jib.
They fold in half.
So maybe if someone could make a titanium or carbon fiber pole that could do double duty.
..then it's a shame that the racing rules in most parts of the world specifically prohibit the use of something as simple as a boat hook for spin pole/whisker pole duty. For some reason ISAF think a large sail attached to a boat hook attached to a person is a good way to get said person badly injured..
Carbon fibre spinnaker poles are the norm on racing yachts I've been on. Yes they're light(ish) but given the diameter and length they need to be to take the strains imposed by the sails and do the job they're designed to do, there's no way I'd even contemplate using one as a boat hook - it'd be physically too unwieldy on anything bigger than a dinghy.
Classic30 is offline
post #33 of 36 Old 05-11-2014
Re: Best Boat Hook?
I've always had a 12 ft aluminium pike pole on board.Sharp steel business end. Loggers use them and I often find them floating. In the Beaufort, indispensable for pushing big chunks of ice off the anchor line.In more temperate zones useful for picking up lines ,fending off floating drift wood and the occasional mishandled yankee vessel. Stores along the cabin side Pointy covered in a housing made from defunct white fender material (good stuff for many projects) and the 8 footer stores upright thru a rope eye on the mizzen shroud
Capt Len is offline
post #34 of 36 Old 07-08-2016
Re: Best Boat Hook?
The double hook boat hook that you may be looking for, is the wRino boat hook mooring system, a boat hook with mooring features for attaching lines to most docking and mooring fixtures from the deck of a boat. A winner of the leading marine awards in USA (NMMA), Europe (DAME - nominated finalist) Australia (Aust Marine) for it's simplicity, speed and ease of operation.
For availability Google wrino.
wrino is offline
post #35 of 36 Old 07-08-2016
Re: Best Boat Hook?
I use a painter's pole, extends to about 12ft, strong, sturdy and does the job has a brush handle at the same time
fred1diver is offline
post #36 of 36 Old 07-09-2016
roverhi's Avatar
Re: Best Boat Hook?
Have West Marine 3 section pole but seldom use it because it collapses when you try and push off with it. Probably should see if it still extends and hasn't corroded up. Went back to the old wooden pole which is stowed vertical on the cap shrouds using lashed on rings.
roverhi is offline
How old is your boat hook? FarCry Gear & Maintenance 12 06-24-2013 02:18 PM
Boat hook for whiskerpole Survivor General Discussion (sailing related) 13 10-10-2012 09:35 PM
On a hook? (boat storage Florida) locals help ?! Shortnsalty General Discussion (sailing related) 8 06-15-2012 06:55 PM
hi from the hook chrisncate General Discussion (sailing related) 2 07-18-2010 08:25 AM
