Would PEX work for mast wiring through-deck? - SailNet Community
post #1 of 10 Old 05-06-2014 Thread Starter
scratchee's Avatar
I have a Cal 2-27 and just took the mast down due to evidence of water intrusion down below. As expected, water had been traveling down the wire bundle that goes through the mast step and deck. I would like to properly prepare the hole with over-drilling, epoxy, etc, then use a conduit of some sort to make an inch or two of standpipe above the step, extending down through the deck to act as a conduit. I've been trying to figure out what material to use. I was thinking of bronze, but then I got worried about the bronze running through the mast step made of an unknown metal (3/4" hole in the mast step, by the way.) I thought of PVC, but heard (here) that epoxy won't bond to the PVC. Maybe it doesn't need to, and I can just use some other type of sealant?
Anyway, I have two specific questions:
- What is the established means of getting wiring through the deck inside the mast (I don't want to have a fitting outside the mast as I have seen on some boats?)
- If conduit is a proper solution, what material is best and how should it be secured and/or sealed?
Many thanks as always…
EDIT: Forgot to mention that I bought a short piece of 3/4" PEX today because it was cheap and was a pretty blue color.
scratchee is offline
post #2 of 10 Old 05-06-2014
One of None
deniseO30's Avatar
Re: Would PEX work for mast wiring through-deck?
you need things called "cable clams" and or deck plugs
pex will not last a year in the heat and sun. sorry .
My last project!
deniseO30 is offline
post #3 of 10 Old 05-06-2014 Thread Starter
scratchee's Avatar
Thanks Denise. Do either of those fittings work with multiple cables? I have two electrical and two coax (in a pinch, if space is an issue, I could re-run one of the coax through its original fitting external to the mast.)
I'm doing this internal to the mast, so I don't think sun would be an issue; maybe heat would. But I suspect I'll find out that epoxy and the standard sealants won't bind to PEX anyway.
post #4 of 10 Old 05-06-2014 Thread Starter
scratchee's Avatar
Here's a picture of my mast step. Whatever I use has to fit through that 3/4" hole in the middle:
post #5 of 10 Old 05-06-2014
Enlarge the hole a bit and put the DS-MULTI on it (last one on the page).
Scanstrut ? search results
SVTatia is offline
post #6 of 10 Old 05-06-2014 Thread Starter
scratchee's Avatar
Thanks SVT. I'm seeing that the problem with any fitting is going to be the vertical flanges on the step. They will interfere with anything larger than the hole itself. I think my options will be to either drill another hole elsewhere in the step, or just find a way to seal the hole with sealant/potting/etc. Or go through the deck external to the mast.
I think they call this a "trade study."
post #7 of 10 Old 05-06-2014
I used pvc for a similar purpose (standpipes inside the helm pedestal guard tubes). I don't know how strong the bond is, but the pvc doesn't budge, and no water was come in.
Dave
Pearson 33-2
Western Long Island Sound
davester is offline
post #8 of 10 Old 05-06-2014 Thread Starter
scratchee's Avatar
Thanks Davester. How did you secure and/or seal the PVC?
post #9 of 10 Old 05-06-2014
tommays's Avatar
Out the base and as many clams as you need and there will never be another drop of water
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #10 of 10 Old 05-07-2014
I drilled out the area, taped the bottom, put the pvc sections in place, and poured thickened epoxy around them. I was also replacing the pedestal guard feet which required drilling some new holes, and filling old ones. I didn't seal the inside the pvc tubes, but they aren't getting any water in them. (I have rubber gaskets where the wires enter the guard rail at the top).
Pearson 33-2
davester is offline
Leak at mast wiring deck penetration Rusty123 Gear & Maintenance 17 01-04-2013 12:50 AM
Where does your mast wiring exit the mast? downeast450 Electrical Systems 0 02-27-2012 09:43 AM
Deck/Steaming light wiring question andyjen Electrical Systems 15 01-20-2011 12:46 PM
Deck Stepped Mast Wiring Connection 1970Columbia34 Gear & Maintenance 12 01-03-2008 09:39 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 09:07 AM
