Shroud clips, oversized or undersized? - Page 2 - SailNet Community
 6Likes
post #11 of 31 Old 05-07-2014 Thread Starter
Re: Shroud clips, oversized or undersized?
Ok thanks for the insight, I do not expect hard bends on my stays as I am pretty cautious when raising and lowering.
I made this thread because two of my wires on the dinghy were about half way through slipping out of the sleeve so I was worried if they were enough.
Also I already ordered the wire :X
Is there a way of pressing those things without the specific pressing tool?
Spider0804 is offline
post #12 of 31 Old 05-07-2014
mitiempo's Avatar
There is a hard bend of the wire around the thimble.
Using 2 Nicropress sleeves is all the insurance needed.
The specific too is needed. You can buy it from Duckworks. Here is the link. The sleeves to use are zinc coated copper. They have the thimbles as well.
SWAGE-IT - Swaging Tools and Sleeves
christian.hess likes this.
Brian
mitiempo is offline
post #13 of 31 Old 05-07-2014 Thread Starter
These be what I bought.
http://www.amazon.com/dp/B0013HJXA2/ref=pe_385040_30332200_TE_item
http://www.amazon.com/dp/B0038YY3M6/ref=pe_385040_30332200_TE_item
http://www.amazon.com/gp/product/B0038YY2I6/ref=ox_ya_os_product_refresh_T1
The reason I am replacing the stays is because the current wire is 1x7 and has kinks in it where the previous owner pinched it, also I am upgrading from 1/8" because I was worried the 1x7 1/8" might break after enough time if I use a trapeze.
Also they are 5/32", do you think the smaller 1/8" tool would work or do I have to get the bigger one.
If not I would end up buying one of these.
http://www.ebay.com/itm/Swage-Tool-/...item43c89e21c6
post #14 of 31 Old 05-07-2014
mitiempo's Avatar
The wire, thimble, and sleeves are good. They don't say much about the swaging tool but if it is of reasonable quality it should work.
Brian
mitiempo is offline
The Following User Says Thank You to mitiempo For This Useful Post:
Spider0804 (05-07-2014)
post #15 of 31 Old 05-07-2014 Thread Starter
The 1/8" One you posted, Or the one I posted?
post #16 of 31 Old 05-07-2014
mitiempo's Avatar
The link you posted. The swage tool in the link I posted only does up to 1/8 wire - which would be fine for your boat I would think.
Brian
mitiempo is offline
post #17 of 31 Old 05-07-2014
christian.hess's Avatar
you look good to go to me!
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #18 of 31 Old 05-08-2014 Thread Starter
Yea I was going to buy 1/8 to replace the 1/8 on there but some listed the working load as 400 lb or so, I was worried that with my weight on the mast too from a trapeze, that a line might become over stressed. Figured they put the right line on there for the sails, but not the sails plus me.
post #19 of 31 Old 05-08-2014
mitiempo's Avatar
1 x 19 type 304 stainless wire has a breaking strength of about 1780 lbs.
Brian
mitiempo is offline
post #20 of 31 Old 05-08-2014 Thread Starter
What is the point of working load limit rating then?
Load Limit Definitions
The Working Load Limit is the maximum load which should ever be applied to the product, even when the product is new and when the load is uniformly applied - straight line pull only. Avoid side loading. All catalog ratings are based upon usual environmental conditions and consideration must be given to unusual conditions such as extreme high or low temperatures, chemical solutions or vapors, prolonged immersion in salt water, etc. Never exceed the Working Load Limit.
That is what I am going off of and 1/8" was 400 lbs.
I figured the force of the wind on the sails and my 200 lbs hanging off the side would be greater than 400 lbs of force.
Gennaker that is undersized - dangerous? MikeOReilly Gear & Maintenance 10 04-02-2014 08:50 AM
Undersized Strainer? 4arch Gear & Maintenance 9 12-11-2012 11:04 AM
Oversized rigging brak Gear & Maintenance 19 10-23-2008 01:32 PM
Undersized Genoa dgr Gear & Maintenance 9 08-06-2008 10:00 AM
Undersized charger question Newport41 Gear & Maintenance 7 04-07-2007 10:38 PM
