Shroud clips, oversized or undersized? - Page 3 - SailNet Community
 6Likes
post #21 of 31 Old 05-08-2014
mitiempo's Avatar
Re: Shroud clips, oversized or undersized?
On a larger boat rigging wire is most often tensioned to 15 - 20% of its breaking strength.
Very good rigging guide here:
http://www.riggingandsails.com/pdf/selden-tuning.pdf
Page 28-29 has the loading information
christian.hess likes this.
Brian
mitiempo is offline
post #22 of 31 Old 05-08-2014
Closet Powerboater
MedSailor's Avatar
Ideally you should not be using 1x19 wire bent around thimbles. The 1x19 doesn't like to bend and you'll see the strands start to separate a bit as they are forced around the thimbles.
However, I had 1x19 wire bent around thimbles and swedged with the (doubled) nicopress fittings you posted on my 10,000lb 31ft boat and it did hold up the stick. Personally I wouldn't do it again that way on a keelboat, but the risks are less in a dinghy. You'll probably be just fine, but next time you rig something like this it would be better to use 7x19 wire as it tolerates bending around the thimbles better. Also double nicropress sleeves are never necessary. If the sleeve is slipping, it's the wrong size, or was not pressed on correctly.
MedSailor
MedSailor is offline
post #23 of 31 Old 05-08-2014
christian.hess's Avatar
yup next time chose 7x19
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #24 of 31 Old 05-08-2014 Thread Starter
The order had not shipped yet, I will just grab 1/8" 7x19 instead. 5/16 seems to be a real oddball size that hardware does not support.
MedSailor likes this.
Spider0804 is offline
post #25 of 31 Old 05-08-2014
oh cool then by all means 7x19 its quite a bit more pliable, almost all the dinghies I have had have had this wire
post #26 of 31 Old 05-08-2014 Thread Starter
What about 7x7 wire?
I have found some for half what I can find the 7x19 for.
post #27 of 31 Old 05-09-2014
mitiempo's Avatar
7 x 7 is a lot more flexible than 1 x 19. Should be fine. But get the proper tool to swage it. The wire will never break - a bad swage will.
Brian
mitiempo is offline
post #28 of 31 Old 05-10-2014 Thread Starter
Found a 1/8" to 1/2" swage tool at lowes for 24 dollars, and it is the bolt cutter style. Cant beat that!
post #29 of 31 Old 05-10-2014
mitiempo's Avatar
1/2" swage tool for $24 can't be good quality...
Brian
mitiempo is offline
post #30 of 31 Old 05-11-2014 Thread Starter
Will find out next week I suppose!
Gennaker that is undersized - dangerous? MikeOReilly Gear & Maintenance 10 04-02-2014 09:50 AM
Undersized Strainer? 4arch Gear & Maintenance 9 12-11-2012 12:04 PM
Oversized rigging brak Gear & Maintenance 19 10-23-2008 02:32 PM
Undersized Genoa dgr Gear & Maintenance 9 08-06-2008 11:00 AM
Undersized charger question Newport41 Gear & Maintenance 7 04-07-2007 11:38 PM
