Aries Wind Vane - Page 2 - SailNet Community
 4Likes
post #11 of 19 Old 05-08-2014
christian.hess's Avatar
Re: Aries Wind Vane
ioh btw aries once dabbled in stainless and bronze in the early 80s I beleive and it was a very short run pendulm vane that was all stainless tubing with all bronze connectors and fittings
it was really expensive and didnt catch on...
I came across one on craigslist way back when I had my folkboat however it was too awkward to mount it and I started dabbling and designing my MOTISSIER inspired trim tab vane since it was a perfect match for my rudder
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 19 Old 05-08-2014
outbound's Avatar
Re: Aries Wind Vane
Just curious. Have had Fleming ( bulletproof), monitor and have used Hydrovane. Liked the Fleming the best. My impressions are:
servo pendulums are great and responsive but you get a bunch of lines in cockpit and it takes some fiddling around to get things just right. you have a s+s so tripping over lines may be a hassle.
Servos are great but unless you blow big bucks on the monitor add ons you don't get a emergency rudder function.
Have fairly fast boat with sugar scoop and midline swim steps. So for me any of the servos are not a great choice. So been looking at the hydrovane. Think for less money in the end get a lot more versatility.
?Do you have an AP. If so have you thought about just getting a spare ram and rudder indicator which in the end may be cheaper and also give you steering in light air, motoring and DDW. I am thinking of going that way and making a home made emergency tiller.
s/v Hippocampus
Outbound 46
outbound is offline
post #13 of 19 Old 05-08-2014
Re: Aries Wind Vane
along similar lines I beleive I have a very desired and respected SAYES RIG vane that connects to the rudder
no lines,or pulleys and dead simple system
a version if you will of the trim tab rigs
its somewhere in the junk of stuff that was on my boat
cant wait to actually see if indeed its a sayes rig
post #14 of 19 Old 05-08-2014
MikeOReilly's Avatar
Re: Aries Wind Vane
All good points. If I were installing a vane from scratch (my Aries was already on the boat) I would look long and hard at the auxiliary rudder style vanes. I've never used one, but the idea of having a backup rudder is attractive. Because they do all the work my understanding is their installation is more challenging. The benefit of the servos are they use the boat's rudder to steer, so they don't have to be as hefty.
Btw, my boat uses a tiller, not a wheel. The lines are therefore far aft and out of the way. I've sailed with a wheel using a Monitor vane. Worked fine, but the lines were more of a pita than with my boat.
Why go fast, when you can go slow
Why go fast, when you can go slow.
MikeOReilly is online now
post #15 of 19 Old 05-08-2014
Bristol 45.5 - AiniA
Re: Aries Wind Vane
Originally Posted by casey1999 View Post
I currently have a Monitor wind vane. It works well but is starting to need some major maintenance due to high miles.
I was thinking of replacing it with an Aeries vane. My understanding is the new Aries are made in Denmark. Are these just like the Aeries #3 that was made in England. Are the parts interchangable?
If you know the Aeries, what is your opinion of their quality and function as compared to others on the market.
What about buying a used Aeries- is that a good option? I understand replacement parts are still available from England.
You might consider fixing your Monitor. I have a Monitor and it worked great for us. The only routine maintenance was to lubricate but with fresh water. I kept a little pump spray and did this maybe once a week on a passage. We are going to be doing a major maintenance job on ours since it has been used for more than 30,000 miles. The kit they sell ($135?) has all the bushings and bearings you need. Along the way we replaced one (or two?) turning blocks and had the mounting for the pivot pin beefed up (had washers welded on each side and a big pin made, but that was after 25.000 miles. Also replaced the sacrificial part of the rudder post. I don't think we hit anything rather it seemed like fatigue with cracks starting. It is all stainless which is a nice feature.
The Monitor people in California are very helpful although the spare parts seem a bit pricey. We saw substantially more Monitors than any other vane but that does not necessarily mean they are best - they also have sold more than any other brand. Had two very experienced people independently say that one of the Sailomat models is clearly the best vane but the company stopped making it a number of years ago because it just got too expensive. Don't know the model number.
We thought about a Hydrovane but we are close to the maximum displacement for the unit. The guy who sells them said it should work which did not seem like much of a recommendation. There were three other Bristol 45.5s with Monitors so that seemed a good recommendation. Also, with Hydrovane you may have to reinforce (as in add f/g) the inside of the transom since the loads are very high since you are steering the boat and not just the wheel or tiller. I think our transom was probably strong enough but we had about four sets of hoses going out the transom and it would have been a big install. We installed the Monitor at anchor in Long Island Sound after my wife was laid off and we had to leave the marina in NYC or pay a lot of money for the summer season.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #16 of 19 Old 05-08-2014
Re: Aries Wind Vane
there are many MANY windvanes out there...but there are still standards out there that have become cult classics almost like the aries and monitor
the last time I was looking at new vanes and being latin I was very interested in a argentinian made vane similiar to the bouvaan windvane kits, sailomat, etc
they were priced well and are used in the argentinian waters that are quite the proving grounds if you will
here is the link:
South Atlantic Windvane Self Steering
in any case you have a bunch to chose from...
cheers
oh before that I was really looking at the norvane windvanes but they really hiked their prices a lot since they started
post #17 of 19 Old 05-09-2014
mitiempo's Avatar
Re: Aries Wind Vane
I don't think Norvane prices have changed much since I started looking at them a few years ago. I have yet to see a better priced windvane and my plan is to get one in the near future.
Here is their current price list:
Brian
mitiempo is offline
post #18 of 19 Old 05-09-2014
Senior Smart Aleck
jameswilson29's Avatar
Re: Aries Wind Vane
BTW, there is a used Aries in Key West, FL, currently up for auction on eBay in the sailing hardware subsection.
jameswilson29 is offline
post #19 of 19 Old 05-09-2014
Re: Aries Wind Vane
I cant remember but I was in love with the norvane system after they just started which was in the early to mid 2000s I want to say they started in 2006 since that was when I had my folkboat and was checking them...I beleive the smallest vane was just over 1000 or 1500 bucks...cant remember which was perfect for me
I beleive it was an introductory price since they were new on the market
when they went up I was so dissapointed since I was on even more of a budget back then
those prices you posted are the same since I checked somehing like 6 years ago
man time flies!
I agree though their vane has RAVE reviews
Aries Self steering wind vane VinceJones Gear & Maintenance 8 10-14-2016 12:20 PM
Used Aries Wind Vane -- Should I go for it? obelisk Gear & Maintenance 17 02-02-2013 03:41 PM
Aries Wind Vane Self Steering help Jetexas Gear & Maintenance 2 07-06-2012 03:09 PM
Overhaul an Aries wind vane in Ireland wysiwyg Gear & Maintenance 2 02-04-2009 09:42 PM
Help needed with Aries wind vane install. SchoonerMISTRESS Gear & Maintenance 3 07-08-2007 02:07 PM
