Aries Wind Vane - SailNet Community
 4Likes
post #1 of 19 Old 05-08-2014 Thread Starter
casey1999's Avatar
Aries Wind Vane
I currently have a Monitor wind vane. It works well but is starting to need some major maintenance due to high miles.
I was thinking of replacing it with an Aeries vane. My understanding is the new Aries are made in Denmark. Are these just like the Aeries #3 that was made in England. Are the parts interchangable?
If you know the Aeries, what is your opinion of their quality and function as compared to others on the market.
What about buying a used Aeries- is that a good option? I understand replacement parts are still available from England.
christian.hess likes this.
casey1999 is offline
post #2 of 19 Old 05-08-2014
Re: Aries Wind Vane
I've not used either, I want to mount one on our current boat, but we haven't gotten around to it yet.
I will note (my only useful contribution to the subject) that we looked at putting one on our last boat and I was able to find an Aries pretty cheap ($650) and in good shape, but the thing was absurdly heavy, like 75lbs IIRC. The Monitor was next in weight at ~50lbs, Norvane was 37lbs, South Atlantic 37lbs, and Windpilot 44lbs.
At the time, we had a 27ft boat and were concerned what hanging 75lbs off the back would do. We more or less resolved to get a Norvane before we sold the boat and will probably go that route with our new boat. Even with a slightly larger boat, I'm concerned about that much weight off the stern.
Shinook is offline
post #3 of 19 Old 05-08-2014
christian.hess's Avatar
Re: Aries Wind Vane
bomb proof Ive had one and cruised on another one with the tiltup version
we actually got hit in the stern with a big aluminum boat that anchored to close to us at dusk...in galapagos and 2 days into the crossing to hiva oa we notice the drum was broken!
the one with the teeth
however my captain had power tools and rivets and all sorts of parts and we managed to tie it back together and it worked
during that crossing beleive it or not we were in constant contact with a lady from aries(in england) I beleive via sailmail) that got them the new part somewehere in the south pacific...after I left
its a very very good windvane
does need a bit of help every now and then in rolly seas but overall a great performer
we did however maintain it a lot by that I mean preventatite maintenance we OILED the hell out of the pendulum and gears, and always greased and protected all rviets and stainless parts that touched
the aluminum itself is hardened and very long lasting but as usual with dissimilar metals you will always get some corrosion if you dont peridiodically oil and grease and maintain
my last boat had the standard version mid 80s design...fixed mount
Im not familiar with the new models but dont think they have changed all that much
cheers
MikeOReilly and casey1999 like this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #4 of 19 Old 05-08-2014
MikeOReilly's Avatar
Re: Aries Wind Vane
I have an Aries (not sure which one, has the flip up rudder). It came with our boat and I had to do some repairs to get it operational, but it's been great. Steers better than me most of the time. Lights airs and rolling seas are a challenge for all servo-pendulum vanes, but our will maintain a course down to 5 knots if seas are not a problem.
What Christian says about oiling and greasing, but is one solid pieces equipment.
I don't think the Denmark parts are interchangeable with the original ones made in England. The daughter of the original maker still maintains a parts service for the old ones. I was able to get a package of parts from her a year or two ago. She's great, but you do have to be patient sometimes.
Why go fast, when you can go slow
Why go fast, when you can go slow.
MikeOReilly is online now
post #5 of 19 Old 05-08-2014 Thread Starter
casey1999's Avatar
Re: Aries Wind Vane
What kind of oil and grease do you use on your aries?
Thanks for the inputs.
post #6 of 19 Old 05-08-2014
Re: Aries Wind Vane
thats who we were in touch with!
post #7 of 19 Old 05-08-2014
Re: Aries Wind Vane
we used 2 stroke oil, castor oil, motor oil whatever oil...doesnt really matter
the grease was some sort of lithium grease
tef gel or something like you use on mast tracks and stainless hardware is another obvious option
forget the names sorry
post #8 of 19 Old 05-08-2014
Re: Aries Wind Vane
2 stroke oil btw has many uses on a boat and engines in general
its great to lube the top ends(minimal amount) on older gas engines like the atomic 4, it leaves a residue and has lubricants that standard oils dont
aircooled engines for example
since it leaves residue it lasts longer I have noticed and I forget what it helps with in diesel but helps fight something
sorry cant remember
back to aries!
post #9 of 19 Old 05-08-2014
Re: Aries Wind Vane
We use the engine oil, b/c that's what's on hand. I think the grease is a lithium type. It's an industrial type of grease. We were given a big tube a few years ago, and it's still going strong. I'll have to go look at it the next time I'm on the boat (still winter up here).
post #10 of 19 Old 05-08-2014
Re: Aries Wind Vane
you have learned all the tips mike! cool!
I love the aries windvane
The Following User Says Thank You to christian.hess For This Useful Post:
MikeOReilly (05-08-2014)
Aries Self steering wind vane VinceJones Gear & Maintenance 8 10-14-2016 12:20 PM
Used Aries Wind Vane -- Should I go for it? obelisk Gear & Maintenance 17 02-02-2013 03:41 PM
Aries Wind Vane Self Steering help Jetexas Gear & Maintenance 2 07-06-2012 03:09 PM
Overhaul an Aries wind vane in Ireland wysiwyg Gear & Maintenance 2 02-04-2009 09:42 PM
Help needed with Aries wind vane install. SchoonerMISTRESS Gear & Maintenance 3 07-08-2007 02:07 PM
