Deck Hardware - SailNet Community
 4Likes
post #1 of 22 Old 05-09-2014 Thread Starter
safira's Avatar
Deck Hardware
I have been trying my darnedest to find a person or company to make 4 of these for me, with no success!!
Any help with making a connection so I can get them and install them would be greatly appreciated!!!!
They are for the shrouds or rigging.
safira is offline
post #2 of 22 Old 05-09-2014
Re: Deck Hardware
Where are you located. I can make them.
Bud
christian.hess likes this.
AkaBud is offline
post #3 of 22 Old 05-09-2014 Thread Starter
safira's Avatar
Re: Deck Hardware
I am in St Marys Georgia
can you give me a price?
safira is offline
post #4 of 22 Old 05-09-2014
Asleep at the wheel
jimgo's Avatar
Re: Deck Hardware
Are they chainplates? Do they just screw into the deck, or do they also pass through?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 22 Old 05-09-2014
christian.hess's Avatar
Re: Deck Hardware
any machine shop that has acces too good 304, 316 stainless
those are 304 more than likely and there is nothing to it really
are they tied into a plate below?
it looks like they are the type that goes through the deck and tie under with nuts but the plate actually is also tied under toa bulkheads or knee or something
Id offer to make them here and send them up but it wont be cost effective for your though
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #6 of 22 Old 05-09-2014 Thread Starter
safira's Avatar
Re: Deck Hardware
They go thru the deck and have a backing plate on them ..... I am useing them on the shrouds for the main mast ....
safira is offline
post #7 of 22 Old 05-09-2014
Re: Deck Hardware
yeah thats what I thought
is the backing plate real big? like bigger than the top part? not toed to anything else?
I know this goes against what a lot of people say but your friend here is 304 stainless
its what most stainless hardware fittings were made out of back then and is also less brittle
having said that like the pics show they sirface rust more and dont look as good
in any case
good luck
post #8 of 22 Old 05-09-2014
Re: Deck Hardware
I need a little more info. Can you send me a sketch with dimensions.
Do you need the baching plates too.
rv-6 at comcast.net
AkaBud is offline
post #9 of 22 Old 05-10-2014 Thread Starter
safira's Avatar
Re: Deck Hardware
rv-6 at comcast.net
Sent you a mail to see if you got it, not sure if that is a e-mail or not.
In answer to your question ... yes will need backing plates also
safira is offline
post #10 of 22 Old 05-10-2014
no longer reading SailNet
Alex W's Avatar
Re: Deck Hardware
It would be good to see what is going on inside the boat. If those are chainplates then it seems like you would want more than a backing plate on the inside, something needs to transfer the load into the boat's hull or bulkhead. The deck typically can't handle that sort of load.
This is a very similar product that is already made:
Tow Pad Eye
This is the style of backing plate/chainplate that I would expect for rigging loads. It attachs to a deck mounted padeye like the one shown, but transfers all of the load from the deck to a bulkhead:
My boat uses something like that under the backstay padeyes to transfer load from the deck to the transom.
jimgo likes this.
Alex W is offline
Re-bedding deck hardware drynoc Gear & Maintenance 6 11-02-2003 05:00 AM
Deck hardware natejount Gear & Maintenance 9 07-29-2003 12:10 PM
Deck Hardware Don Casey Gear and Maintenance Articles 0 09-27-2002 09:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
deck hardware blizzard Gear & Maintenance 1 10-18-2001 09:54 AM
