port light leaking catalina 30 - SailNet Community
 1Likes
  • 1 Post By davidpm
post #1 of 6 Old 05-09-2014 Thread Starter
davidpm's Avatar
A friend is buying an old Catalina 30.
The survey will turn up a leaking port light.
Port side aft.
The design is a metal ring set into the fiberglass then a Plexiglas fixed light set in the metal ring secured with a flexible strip on the inside.
It appears to be leaking between the plexi and the ring as If I lift the flexible strip the metal channel is full of water.
Other than buying the repair or replacement kits any successful repairs?
davidpm is offline
post #2 of 6 Old 05-09-2014
The most female moderator
Donna_F's Avatar
Dock
Re: port light leaking catalina 30
Is there a question?
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #3 of 6 Old 05-09-2014
Brewgyver's Avatar
Originally Posted by davidpm View Post
(snippage)
Unless they're highly experienced in fixing anything with nothing, they'll probably need to buy something.
Used to see a sign to that effect:
"We, the unwilling,
led by the unknowing,
are doing the impossible
for the ungrateful.
We have done so much,
for so long,
with so little,
we are now qualified to do anything
with nothing."
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
The Following User Says Thank You to Brewgyver For This Useful Post:
oysterman23 (05-09-2014)
post #4 of 6 Old 05-09-2014
christian.hess's Avatar
we just redid similar portlights david except with plastic sigh outer rings
id be happy to show your pics of them sealed up again and 40 years old and still going
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
The Following User Says Thank You to christian.hess For This Useful Post:
davidpm (05-10-2014)
post #5 of 6 Old 05-10-2014
Asleep at the wheel
jimgo's Avatar
David,
For quick fixes, some on the C25 site suggested flowable silicone, which can be found at auto parts stores. I did that on my C25, and it seemed to work. On the Allmand, I have rebedded with Maine Sail's butyl. We'll see how that works.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
post #6 of 6 Old 05-11-2014 Thread Starter
davidpm's Avatar
Problem solved, almost.
Found a box from catalina direct with the repair kit for all the windows.
Just not installed.
christian.hess likes this.
davidpm is offline
Leaking port lights Allegro1 Gear & Maintenance 9 11-11-2014 06:47 PM
Butyl Tape and leaking port-light RossC32 Gear & Maintenance 12 11-24-2011 05:41 PM
leaking Lewmar opening port sails7plj Announcements and Suggestions Box 0 03-07-2010 11:13 AM
Rudder port leaking, bolts toast - what to do? FishFinder Gear & Maintenance 13 10-06-2008 12:27 PM
Leaking Catalina Fuel Tank - Help!?! grizzly Gear & Maintenance 4 11-24-2007 04:45 PM
