04-08-2006
Go to an automotive supply store and get some 'fine' valve grinding compound - this will be used to re-polish the barrel and the plug. Remove the plug, apply the compound to both the plug and inner part of the barrel and turn (rotate - dont just 'rock-back-and-forth') until all is cleaned and repolished ... dont get carried away or the plug wont fit and the nuts will be too 'far away' to the side of the barrel when assembled - polish dont 'grind' deeply into the surface.
(If you do this in the water, jamb plumbers putty into the throughull to 'stop the flood' -- its BEST to do this when the boat is hauled).
The BEST sealing compound (auto store stuff) for the tapered plug valves is 'waterproof' wheel bearing grease ... try to find a WB Grease that has 'fiber added'. Apply to the barrel and plug, assemble the plug to the barrel and 'slightly tighten' the nuts and washers of the plug to the valve ... but NOT so tight so as to squeeze all the grease out of the valve .... just tighten so that there is a 'wee little bit of drag' when you rotate the handle - not so loose that there is no drag but not enough so that you dont squeeze all the grease out.
