Need help with Seatech fittings - SailNet Community
post #1 of 6 Old 05-13-2014 Thread Starter
Crealock 37
sailak's Avatar
Dock
I have a 1995 PSC 37. According to Thumper at PSC the potable water lines used at time of building were either Seatech or Whale.
Mine appear to be Seatech but I can't figure out how to disconnect the fittings.
This first photo is of one of the connectors.
Sorry for the crummy pic. This is after popping the end cap off. I had assumed you push the gray collar toward the fitting but I was unable to get it to move.
Any help is appreciated.
Thanks
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #2 of 6 Old 05-14-2014
Re: Need help with Seatech fittings
I would assume, I don't know that they were like a electrical shrink fitting. Meant to last as
long as they last. Cut them off and replace them.
Zen is a matter of recognizing reality.
desert rat is offline
post #3 of 6 Old 05-14-2014
The ring on the right in your photo (blue arrow) is a protective cover to prevent accidental disengagement. Once it's off, you push the ring on the left (red arrow) in while pulling the tubing out to disengage. The system must be de-pressurized to get it apart.
See: Installation Guidlines for Quick Connect Fittings - Technical Information - Sea Tech, Inc.
IStream is offline
post #4 of 6 Old 05-14-2014
I suggest a wrench as the best way to press on the ring. You might have to jiggle the hose a bit, it's been in there for a while and it's happy where it is.
Try this : While pushing on the ring with the wrench, push the hose in further, then pull hard.
MarkSF is offline
post #5 of 6 Old 05-14-2014
Old enough to know better
I know the "Gator fittings" and "Shark Fittings" have a tool that snaps over the tube, and you use that to push the ring into the fitting. You might check Home Depot or Lowes to see if they have a tool that would fit. It will come undone, but if it has been on for a while I would not think it will seal again because the O-rings will likely have deformed. They seem to be connect several times while setting them up, but once on for a year or two they won't disconnect and re-connect without leaking. Or so it has been my experience, especially if it is a hot water line.
http://www.homedepot.com/p/SharkBite...5yc1vZbqpfZ4n3
Likely would work. I don't like the fittings in a house where they are hidden but on a boat they would work well. I have used them in a house, but only over a drop ceiling where there is good access if it ever needs to be replaced. I prefer the crimp fittings, and once you have the tool they are much cheaper.
miatapaul is offline
post #6 of 6 Old 05-14-2014 Thread Starter
Crealock 37
sailak's Avatar
Dock
Thanks folks, heading to the boat in the morning to try your ideas.
Dale
S/V Elnora
sailak is offline
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
plumbing with Seatech? degreeoff Gear & Maintenance 1 02-13-2010 06:07 PM
Swage fittings? Maverick1958 General Discussion (sailing related) 10 12-18-2009 10:59 AM
SeaTech Marine Training aphil138 General Discussion (sailing related) 1 11-30-2008 08:38 PM
Thru Hull Fittings 1970Columbia34 Gear & Maintenance 3 02-16-2007 11:18 PM
