Need small polisher - SailNet Community
post #1 of 10 Old 05-16-2014 Thread Starter
Need small polisher
Like a lot of people, I have the Northern Freight 7" Polisher-Sander I picked up for around $40. For my needs it does a good job.
However, I really could use a smaller, 4" or so, variable speed unit to get into those tighter spaces around my boat. I don't want a random orbital unit.
I've really searched the web and they are far and few between and cost big bucks.
Anyone know of a small 3-4-5" unit that won't break the bank? I'd like to get exactly what I have now, just smaller.
Catalina 34
chuck53 is offline
post #2 of 10 Old 05-16-2014
Dock
Re: Need small polisher
Cheapest "small" one I've been able to find, runs about $100 most places:
Griots 3" Random Orbital Buffer - Best Three Inch Orbital Polisher by Griots Garage
1970 Islander Excalibur 26 - Retired
CharlzO is offline
post #3 of 10 Old 05-16-2014
Just get a small wheel kit and put it on a cordless electric drill.
http://www.amazon.com/TCP-Global%C2%AE-Premium-Detail-Mini-Buffing/dp/B0021KZFCA/ref=sr_1_3?ie=UTF8&qid=1400257780&sr=8-3&keywords=3+inch+polish+wheel
Jeanneau 54DS
Minnewaska is offline
post #4 of 10 Old 05-16-2014 Thread Starter
Thanks guys. I've seen the Griot unit and I'm sure it's good, but I prefer not to have an orbital unit. I really like a variable speed polisher.
The drill is an option, but I prefer a right angle type of polisher. Again, I really like my 7" NF unit - I want the same, just smaller and I just can't seem to find anything like what I want.
Catalina 34
chuck53 is offline
post #5 of 10 Old 05-16-2014
Dock
Only problem is they get away from cheap in a hurry.
CHENG Concrete Exchange - Kawaii 5" Wet Polisher GWEP150
Max disc 5" but it looks like plenty of space to step down to 4" easily.
Obviously it's a wet polisher, but you wouldn't have to use that option if you didn't want to. I think the other thing, is electric vs air. If you had a compressor setup, I've seen a ton more in that line-up. Again though, takes Cheap out the window
CharlzO is offline
post #6 of 10 Old 05-16-2014
tommays's Avatar
I have quite a home and work collection of grinders
A small rotary unit with Variable speed is going to be air as the electric 4" motor would burn out at polishing speeds
And a small Air unit would get in tight corners and be possible to run with a somewhat small compressor
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 10 Old 05-16-2014
Get a right angle drill?
Jeanneau 54DS
post #8 of 10 Old 05-16-2014
tommays's Avatar
My Ryobi 18 volt right angle at 69 dollars would drive a pad on small jobs
Tommays
Northport NY
tommays is offline
post #9 of 10 Old 05-16-2014
Delta-T's Avatar
Originally Posted by Minnewaska View Post
With...http://www.amazon.com/Papa-Johns-Toolbox-Right-Attachment/dp/B0009X6NOK
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #10 of 10 Old 05-16-2014 Thread Starter
Delta...that's a possibility. Thanks.
Catalina 34
chuck53 is offline
Variable speed polisher recommendation chuck53 Gear & Maintenance 12 04-22-2014 11:12 PM
Polisher and compound... Homework done, no fighting! tipitina Gear & Maintenance 10 01-21-2012 02:48 PM
Diesel Polisher/Water Separator TankMate Diesel 1 12-30-2009 03:16 PM
$50.00 Fuel Polisher timebandit Diesel 2 09-17-2009 01:27 PM
Awl Grip Polisher ambianceack Gear & Maintenance 6 04-12-2007 09:35 PM
