Fuel tank sending units / gauges - SailNet Community
 3Likes
post #1 of 33 Old 05-18-2014 Thread Starter
"Oh, by the way...." the boat's former owner said, as he handed me the key, ".... the fuel tank gauge doesn't work. Not sure whether it's the sender or the gauge." Ah blast - thought I - another "little" job. He told me how much fuel the engine burns per hour and that will help if I remember to record the hours every time we motor somewhere. Or I can do what at least two friends did to deal with the same problem: get a stick that would reach to the supposed bottom of their tanks, calculate the number of gallons a full tank would hold, mark the stick in units of one's choosing (usually gallons) and move on. I'm a bit more uptight than that about reliability and accuracy so I am considering replacing whatever has failed in the system. Components I can think of: sending unit, wiring and gauge. Is there anything else hiding in there? My real issue is the difficulty accessing and replacing the two terminal units, the sender and the gauge. I haven't investigated either but expect that like most items on sailboats, they will not be simple. Any words of advice (short of " hire a mechanic, stupid")? Anecdotes are even welcome. My research so far reveals a bunch of sending units and gauges available out there, none of which look "universal". On top of that the boat, a C&C 29 MK I, was re powered from gas to diesel some time ago and there don't seem to be a lot of associated service records in anyone's files. Words of advice joyfully accepted; commiseration appreciated; sympathy probably wasted - it's my own damned fault.
MRBLIGH is offline
post #2 of 33 Old 05-18-2014
tommays's Avatar
Re: Fuel tank sending units / gauges
Troubleshooting Those Pesky Marine Gauges! - BoatingHowTo.com
This or there is much info in google "how to test boat gauges "in text and tube
It is pretty simple once you understand the basic functions
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 33 Old 05-18-2014
JimsCAL's Avatar
Actually the units are (mostly) pretty universal. Circuit is pretty simple - the sender and gauge in series. The sender's resistance changes as the float moves up and down. Most common range is 240 to 33 ohms. This varies the voltage at the gauge. The Gauge is basically a voltmeter calibrated in tank level rather than volts. You can trouble shoot the system easily with a basic digital multimeter.
JimsCAL is offline
post #4 of 33 Old 05-18-2014
Learning the HARD way...
eherlihy's Avatar
BOTH the sender AND the gauge need to be properly grounded... DAMHIK.
eherlihy is offline
post #5 of 33 Old 05-18-2014
Don't shoot me. Make a list of all the things you should repair, replace, or modify concerning the fuel system. Then arrange the current sender-gauge project to make
it as simple as possible and perhaps solve others at the same time.
Zen is a matter of recognizing reality.
desert rat is offline
post #6 of 33 Old 05-18-2014
I replaced my sender with a mechanical unit. The guage sits on top of the tank. It's totally reliable. Depending on where your tank is this may be an alternative for you.
SteveInMD is offline
post #7 of 33 Old 05-18-2014 Thread Starter
You know, Steve, you are on to something. I like it. I will take a serious look at following your lead. Thank you.
MRBLIGH is offline
post #8 of 33 Old 05-19-2014
eherlihy's Avatar
When my boat was built in '87, the manufacturer installed a Moeller fuel gauge on top of the tank, which could not possibly be viewed by a human. The cockpit was about 2" over the gauge, and this was about 12" away from the lazerette. Here is a pic;
Fortunately, this gauge was set up to be used as a sender if a gauge was installed. Why they didn't install an electric gauge?? I can only guess... You can see the nuts that are used as contacts on the sender.
I installed an electric gauge next to the electrical panel, and initially figured that the ground for the electric gauge light was the ground for the unit.
When I went to try it, no reading... After hours of troubleshooting, and being trained to install gauges by the MMTA (see my signature), I went out and bought a new sender. More hours of installation and troubleshooting, and the I got the same result. "It must be a DOA electric gauge," I thought, and so returned the one that I had been trying to install. I installed a new gauge, same result...
Finally, I noticed the other ground lead on the electronic gauge and connected it. Voilla!
jimgo likes this.
eherlihy is offline
post #9 of 33 Old 05-19-2014
One of None
deniseO30's Avatar
We we replaced the tank in my boat with a poly tank from Moeller the sending unit worked fine for that season with the old guage. after that it stayed on 1/2 ever since.. I'm still not sure if that's 1/2 full or 1/2 empty.. ... But it's not a big issue I just open the lid to the laz and can see the fuel level.
Hopefully the new fuel gauge will work on the "old" Moeller sending unit.
My last project!
deniseO30 is offline
post #10 of 33 Old 05-19-2014
Sight tubes. yer done. simple is good.
Multihullgirl is offline
Portable fuel polishing units chuck53 Gear & Maintenance 15 08-04-2012 01:49 AM
Fuel sending unit leaking Donaldpeter Gear & Maintenance 5 12-20-2010 10:12 PM
VDO sending units GentleBreeze Gear & Maintenance 0 03-04-2008 11:40 PM
Fuel Gauges teshannon Gear & Maintenance 17 07-18-2007 02:42 PM
Sending Unit for DET MAR Fuel Gage ABullard Gear & Maintenance 3 01-29-2003 05:14 AM
