Fairing interior fiberglass after core replacement - SailNet Community
 6Likes
post #1 of 14 Old 05-20-2014 Thread Starter
Hello, I'm looking for advice on how to finish a recoring project. I've recored around the deadlights on a Tanzer 22 and need to make everything look nice again. I removed the interior fiberglass skin for the recoring and have epoxied it back in place. Now I need to decide how to proceed. Should I sand out a wider "v" in the cut and just fill it with epoxy fairing compound (followed by primer/paint), or do I need to do it the "right" way and sand a 12:1 bevel which I fill with fiberglass cloth and then fair?
I ask because most of the recoring examples I've seen are on the exterior. This isn't a structural seam, and it doesn't need to be waterproof. As such, I'm hoping I might be able to get away with just epoxy fairing (much quicker, especially the sanding prep).
I would appreciate any advice, particularly from someone who has made a similar repair. Thanks.
Picture for context, further pictures can be found on our website.
jhock is offline
post #2 of 14 Old 05-20-2014
christian.hess's Avatar
Re: Fairing interior fiberglass after core replacement
yup
here ya go
and
used a product called jet bond to fair...
after it cures sand smooth and repaint
your cabin sides are in much better shape than mine were after taking off the veneer
good luck
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #3 of 14 Old 05-20-2014
I Use Awlgrip Awlfair. It's Allot Of Work. To Get Some Thing Fair Might Take 10 Applications.
christian.hess likes this.
Shockwave is offline
post #4 of 14 Old 05-20-2014
tommays's Avatar
Personally i can live with the white paint
I sure as hell was not gonna put filler in and sand even more
mbowser and christian.hess like this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 14 Old 05-20-2014 Thread Starter
If I take the epoxy only route, I intend to use fumed silica thickened epoxy to do the majority of the filling (for strength and because I find it easy to work with) and finish it off with either West System's 410 microlight filler or System Three's Quick Fair (simply because that is what I have on hand).
christian.hess, have you sailed since making your repair? The only reason I can imagine glass being useful in this situation is to prevent cracking around the faired joints (since the epoxy will flex differently than the surrounding glass).
tommays, nice work, that could not have been an easy job overhead. I'll remember that when I get frustrated working on a vertical surface. And sanding is the worst, I'd much rather be sailing or doing just about anything else.
jhock is offline
post #6 of 14 Old 05-20-2014
hi...what glass are you reffering to? the cabin sides have been faired after removing the wood veneer
its jetbond which is a chemically hardened bondo type fairing compound, then primer, then paint
no glass was used on the sides
the glass you might be reffering to is from the new bulkheads and filleting done
cheers
post #7 of 14 Old 05-20-2014 Thread Starter
cheers
Sorry, my mistake, I'm working from my own paradigm. I cut off the interior glass "skin," removed the core material and then put it all back together with new plywood (reusing the old glass skin). From the picture I thought you had done the same, but you replaced the wood veneer completely with jet bond, correct? Has it dealt well with flexing?
jhock is offline
post #8 of 14 Old 05-21-2014
no not yet but its really firm...Ive seen other model boats like mine do the same, remove the veneer and fair...yes its thin, but i dont see an issue structurally at least...the veneer added no stiffness or strength to my eyes...
I thought about adding wood again but the issue with that was water intrusion and basically more work anytime I have to mess with the windows, or add hardware etc...
post #9 of 14 Old 07-14-2014 Thread Starter
I thought I'd post an update in case anyone else is performing similar work on their boat.
I opted for the 'hard way' taking an angle grinder to the seam, using glass tape to build it back up, and then fairing over it with System Three QuikFair before painting it with Pettit Ez Cabin Coat. Here are some pictures, or you can also find the details on our webpage.
IMG_20140526_171218small.jpg   DSCN1655small.jpg   DSCN1660small.jpg   IMG_20140601_175604small.jpg   IMG_20140602_174014small.jpg
Tempest and deltaten like this.
jhock is offline
The Following User Says Thank You to jhock For This Useful Post:
deltaten (07-14-2014)
post #10 of 14 Old 07-14-2014
Tartan 27' owner
CalebD's Avatar
Thanks for your update.
Looks like a solid repair job.
Well done!
Now I just have to do the same, or similar on my own boat where I re-cored.
Everybody has one:
CalebD is online now
Fiberglass/core question D Schuller Gear & Maintenance 5 10-08-2013 02:39 PM
Deck Core Replacement StormBay Gear & Maintenance 6 11-29-2010 05:12 PM
Interior Fiberglass / Rhino Lining Question mceveritt Gear & Maintenance 7 04-15-2010 05:43 PM
Deck Core replacement zz4gta Gear & Maintenance 59 03-03-2009 10:12 AM
Laying teak over fiberglass interior Warigence Gear & Maintenance 5 02-26-2009 01:44 PM
