USCG Diesel Engine Venting Requirements - SailNet Community
post #1 of 6 Old 05-21-2014 Thread Starter
I just took the USCG's virtual inspection and the only thing it said we were lacking is proper venting and blower for the boat's motor. I went back to the beginning to make sure I'd selected inboard diesel (and I had) and reviewed the requirements on the USCG's page and no where did I see that there had to be a dedicated vent and blower for a diesel engine, only for a gasoline engine. Did I miss something?
"Realization" 1983 Hunter 34
momclarissa is offline
post #2 of 6 Old 05-21-2014
Dirt Free
boatpoker's Avatar
Re: USCG Diesel Engine Venting Requirements
You missed nothing, there is no such standard.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #3 of 6 Old 05-22-2014
I believe this to be an error. I think I asked the same question to this forum after using the same tool. However, I did NOT fail the actual VSC despite not having a blower for my inboard diesel.
MarkSF is offline
post #4 of 6 Old 05-22-2014
Kynntana (Freedom 38)
gamayun's Avatar
This is for gasoline engines only. Just talked to a VE on Saturday about this to do an inspection for my boat, which has a diesel and it does not apply.
gamayun is offline
post #5 of 6 Old 05-22-2014
Don't call me a "senior"!
Puddin'_Tain's Avatar
Blowers are not required for boat with diesel engines. However, they do get rid of excess heat in the engine compartment, and help to keep the almost inevitable diesel smell out of the main cabin.
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
post #6 of 6 Old 05-22-2014
Dirt Free
boatpoker's Avatar
The Regulations are covered under Title 46 and Title 33 of the United States Code of Federal Regulations, the word "diesel" does not appear anywhere in those regulations.
Looking for Used Diesel Engine Loper_27 Boat Review and Purchase Forum 2 06-04-2012 04:56 PM
USCG Seeks Input on Engine Cutoff Switches jjablonowski Seamanship & Navigation 6 06-25-2011 07:20 PM
USCG National Vessel Movement Center requirements EvanstonJohn Caribbean Islands 10 04-20-2010 02:01 AM
USCG diesel tank regulations I33 Gear & Maintenance 17 02-18-2010 07:13 PM
just venting. jbarros General Discussion (sailing related) 0 10-01-2003 02:46 PM
