Flexible Holding Tank, Nauta vs Vetus? - SailNet Community
 1Likes
  • 1 Post By hopcar
post #1 of 6 Old 05-22-2014 Thread Starter
I know I shouldn't buy a flexible holding tank because they smell and can leak. Go ahead, ask me how I know....but now that I've decontaminated myself, my boat and thrown out that damn rotting bag of filth (it was 25 years old), I realize there isn't enough room to install a proper solid tank in it's place under the bunk. I can't seem to find any other suitable locale for a real tank without necessitating long hoses and exhausting installation...really, I just want to go sailing, so I'm back to the bag-of-yuck idea again. I see 2 companies, Nauta and Vetus, that make them. Can anyone compare these two products? I'll probably replace them properly in a few years regardless, when I have a little more courage...
jakmedic is offline
post #2 of 6 Old 05-22-2014
Re: Flexible Holding Tank, Nauta vs Vetus?
Vetus make good hatches, if it's the same company... but you might be a candidate for a desiccating/composting toilet. Check out C-Head. I'm a satisfied customer
Multihullgirl is offline
post #3 of 6 Old 05-23-2014
If the bag fits, why won't the same size poly tank fit? You can have them custom made, although, it can get pricey.
Jeanneau 54DS
Minnewaska is offline
post #4 of 6 Old 05-23-2014
JimsCAL's Avatar
My Cal 33 has a Nauta flexible tank. My previous boat had a flexible tank and it was a constant headache. Replaced it with a rigid poly tank. Assumed I would have to do the same with this one, but it has been fine, so that project got moved down the list.
JimsCAL is offline
post #5 of 6 Old 05-23-2014
fallard's Avatar
My boat originally had a Nauta PVC flexible tank, which was odor-permeable. I have since replaced it with a Nauta tank that is nitrile-lined, after talking with a Nauta rep who mentioned that you should never use a PVC flexible tank--Nauta or otherwise--for your waste tank. The tank I have is also rated for diesel. I have used a similar flexible tank for extra water.
Agree with Minne: get a poly tank if it is cost-effective. The flexible tanks have never failed/leaked, but I would probably be more comfortable with a rigid poly tank that didn't wiggle.
fallard is online now
post #6 of 6 Old 05-24-2014
I had a Nauta holding tank on my boat and I'm familiar with the Vetus tank. I don't think there is much difference. At best they're ok.
I think Aero Tec Labs (ATL) makes the best flexible tanks.
Aero Tec Laboratories - Aero Tec Labs - Aerotech - ATL - Aerotec - AeroTech Labs, Fuel Cells_Cell, Bladders_Bladder, Bladder Tanks_Tank, Potable Water Bladders, Pillow Tanks_Tank_Containment, Portable Tanks_Tank, Liquid Storage, Collapsible Tanks_Tan
I bought a poly tank from Ronco plastics to replace my Nauta.
They have about 500 stock designs you can order and they will install the fittings where ever you want them. When you look at the designs, don't forget you can turn them anyway you want.
Ronco tanks have thick walls and don't seem to allow odors to penetrate.
Ronco Plastics - Marine Water Tanks, RV Water Tank, Auto Detail Tanks, Water Tanks
chef2sail likes this.
hopcar is offline
Flexible holding tank location db27513 General Discussion (sailing related) 16 11-26-2013 05:28 PM
Orientation of Flexible Holding Tank kjzerr General Discussion (sailing related) 7 11-22-2012 08:05 AM
Nauta holding tank fill fitting as vent? jaschrumpf Gear & Maintenance 2 03-22-2010 09:27 PM
Flexible holding tank installation sarafinadh Gear & Maintenance 29 10-17-2009 08:46 PM
Nauta fuel bladder for "holding tank"? jaschrumpf Gear & Maintenance 6 02-22-2009 07:52 PM
