Marlinspike?! - SailNet Community
 1Likes
  • 1 Post By scratchee
post #1 of 7 Old 05-22-2014 Thread Starter
Marlinspike?!
Anybody have a better guide on how to properly use a marlinspike knife? I got this one for my birthday but this guide doesn't really give me good instructions: How to use a Marlinspike | Best Sailing Knife Reviews
Something with animations would be super useful. I feel like I'm the old dog trying to learn a new trick. I guess it's not new to most of you though!
Oldschooner68 is offline
post #2 of 7 Old 05-22-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Marlinspike?!
As the link states; the spike is used ion a lot of ways, none of which should need 'animated' instructions.
Primarily, the spike is used to un-lay strands to run others thru; ie:splice. I've used mine to tame unruly andtightened knots. The Victorinox :"Mariner" I have has a flat tapered tool to use as a spike.While not quite as efficient as a standard spike, it does trial duty as a screwdriver and shackleekey.
Other uses are only limited by you. imagination, physics and engineering
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #3 of 7 Old 05-22-2014
paulk's Avatar
Re: Marlinspike?!
Before pop-tops, they were great for opening beer cans. It was a good idea to engage the lock first, of course, when using it for that.
paulk is offline
post #4 of 7 Old 05-22-2014
Old enough to know better
Re: Marlinspike?!
They make a good pokey prody tool. You can use the spike to separate strands of rope for splicing, but that is advanced stuff. For every day use the most likely to be useful is to help untie knots that have been in a line for a long time. You work into the knot kind of following one end of the line, and just get it in there and kind of wiggle it, just a little bit. It will eventually loosen the whole thing up, and then you can untie it like your kid just tied it an hour ago.
By the way the website you linked to was basically useless. Hope it is not yours.
What knife did you get?
miatapaul is offline
post #5 of 7 Old 05-22-2014
Kynntana (Freedom 38)
gamayun's Avatar
Re: Marlinspike?!
This is how I use mine, primarily to lift the corner of the sole boards that have just enough room to fit the spike into. The curve and taper are better than whatever you'd use a screwdriver for IMO. Of course, you could also use it to stab the head of any fish you catch....you know, a quick lights-out process. That's what I always thought a marlin spike referred to
gamayun is offline
post #6 of 7 Old 05-22-2014
manatee's Avatar
Re: Marlinspike?!
Marlinspike Hitch | How to tie the Marlinspike Hitch
Marlinespike hitch
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #7 of 7 Old 05-22-2014
scratchee's Avatar
Re: Marlinspike?!
If you find yourself using your fingernails to pull apart a knot, that's when you break out the marlinspike.
jackdale likes this.
scratchee is offline
Marlinspike Ropework.....Show Us Yours! supergrade General Discussion (sailing related) 12 09-01-2011 10:43 AM
Marlinspike Seamanship Strength patrickrea Gear & Maintenance 20 02-19-2009 04:43 PM
