Air & Moisture Filter - SailNet Community
post #1 of 5 Old 05-25-2014 Thread Starter
skisail
Hi There, my yacht gets condensation inside the hull, Does anybody know of a solar powered fan that can also act as a moisture filter to remove the condensation. Thanks
Ski Sail is offline
post #2 of 5 Old 05-25-2014
Re: Air & Moisture Filter
You might consider a Nicro Day / Night Plus Stainless Steel Solar Vent
Power - 1000 Cubic Feet per Hour
Vent Diameter: 4", Overall Dimensons: 9" Diameter x 2.5" High
Material: Stainless Steel
ambianceack is offline
post #3 of 5 Old 05-25-2014
JimsCAL's Avatar
Ventilation is key. Can't really remove moisture unless you are running an air conditioner.
JimsCAL is offline
post #4 of 5 Old 05-25-2014
tommays's Avatar
My dorade vents work great
My solar vent is pretty useless IMHP
BUT for example each of my hatch boards also has a SS vent and combined with the dorade box's allow air flow through any time there is a hint of breeze
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 5 Old 05-25-2014
There is no "moisture filter" to stop condensation in a boat. Only small ones to stop condensation in fuel vent lines.
You get a dehumidifier to keep a boat dry, and that's either a big bucket of Damp Rid, or an electric heating rod (GoldenRod) or air-conditioning type dehumidifier. Both requiring shore power.
Other than that, the simple air flow from a couple of adequate solar vents often will stop or reduce condensation. But no, there's no magic "moisture filter" on any of those.
hellosailor is offline
cleaning air filter on perkins 401-8 jasonr575 Morgan 8 02-06-2013 06:46 PM
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 09:23 PM
Yanmar air filter bobmax Gear & Maintenance 2 06-19-2007 08:15 AM
Yanmar 4JH air filter k1vsk Gear & Maintenance 19 12-25-2006 02:17 PM
air filter / flame arrestor owenmccall Gear & Maintenance 0 06-14-2005 08:10 AM
