stainless steel snake? - SailNet Community
post #1 of 4 Old 05-25-2014 Thread Starter
Schooner Captain
UnionPacific's Avatar
I have a small snake I use for clearing up clogs.
Today I used it to clean the AC evaporator coil where the salt water goes thru.
Its maybe only 1/4" diameter, but it has a brush on both ends, I am looking for one about 3' long. the one we have now is steel, and rusting quite badly.
Any leads are appreciated
UnionPacific is offline
post #2 of 4 Old 05-25-2014
Send a message via Yahoo to dacap06
Re: stainless steel snake?
For that use, a light duty stainless steel snake like this one at "http://www.amazon.com/Flexible-Snake-Drain-Millipede-Cleaning/dp/B008ZUNPEA#productDetails" might work for you. Don't use it for heavy duty clogs.
Regards,
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #3 of 4 Old 05-26-2014
Master Mariner
capta's Avatar
Cleaning refer coils and general salt water lines can be easily accomplished by using muriatic acid. As it is quite dangerous, On-Off Hull and Bottom Cleaner does nearly as well, much more safely. Route the exhaust hose into the same plastic bucket as the pick up and run the a/c circulation pump (or any pump) for a few minutes once a year and your a/c lines will be clean and work very efficiently. I don't think your snake or a brush will actually remove all the scale on the inside of the coils.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #4 of 4 Old 05-26-2014 Thread Starter
Schooner Captain
In this situation I believe it was just mud. Once I ran the flexi wire with a brush on it, and reversed the flow, it worked great, and just had dirty water come out. I had thought about a mild acid, maybe even vinegar, but had not a great way to get it thru, other then a funnel on a hose. the pump is mounted 20' away in the engine bilge.
I dont think a snake for a sink would work. the end is too large. I am not sure what this tool is the old owner left on the yacht, but its nearly perfect for the job. Its just flexible wire, with bristles on the ends.
Stainless Steel help. barefootnavigator Gear & Maintenance 8 09-22-2013 04:10 PM
Stainless steel anchors AdamLein Gear & Maintenance 31 07-07-2009 06:08 PM
Stainless Steel... merttan Gear & Maintenance 14 04-12-2008 07:59 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
Stainless Steel Tools Tom Wood Gear and Maintenance Articles 0 09-23-1999 08:00 PM
