Best filtration for freshwater: just particles, or carbon too - Page 3 - SailNet Community
 1Likes
post #21 of 22 Old 05-27-2014
Old enough to know better
Re: Best filtration for freshwater: just particles, or carbon too
Originally Posted by pdqaltair View Post
^^ The "All Clear" is a neat idea that is certainly functions for travelers. There is a pen using the same principle that has been well tested. Simple.
If I were traveling in really pestilential locations UV would be high on my list. All of the challenges are solvable. The problem I have with all of the systems I have seen is some impracticality of operation (they either stay on or they lack a warm-up interlock). But I'd need a health reason I do not have.
I wonder if you could not set up LED UV lights in the tank? They don't use much electricity, and if you have metal tanks should do no harm, but likely would make plastic tanks brittle in no time. I just don't know how much would be enough. Don't want more than necessary(and kill batteries), but must have enough to kill the critters and not just provide a reading light for them. Have them come on via a timer. Keeps the water safe, with no taste.
miatapaul is offline
post #22 of 22 Old 05-27-2014 Thread Starter
pdqaltair's Avatar
You can Google the dose. About 40 mW.s/cm2 for water you are unsure of.
But that's only the tank.
There are also undersink units. Interesting.
I'd need a reason for so much complexity.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
Carbon Masts and Carbon Rigging - the facts? MuddyBottom Sailboat Design and Construction 20 06-15-2011 08:21 AM
whole boat water filtration rmeador Gear & Maintenance 22 11-05-2010 03:28 PM
Water filtration system cla6665 General Discussion (sailing related) 2 09-07-2010 03:17 PM
3M Water Filtration labatt Gear & Maintenance 15 04-22-2009 12:39 PM
Diesel filtration option? maxim_rfeld Gear & Maintenance 7 10-10-2003 12:52 PM
