Refinishing Wooden Spreaders - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree2Likes
  • 1 Post By svHyLyte
  • 1 Post By christian.hess
Old 05-30-2014
captainmurph is on a distinguished road
Since I'm doing a bit of mast down rigging and replacing wiring/antenna, I have my wooden spreaders off.
After a light sanding with a pad sander, they look very good but need a protective finish.
The simplest is to varnish, sand, varnish, sand until I build up 6 coats or more.
Another option is to coat with West system Epoxy and do a couple of coats.
One or two part Epoxy paint is another coption.
And the last involves painting the top white (supposedly deters birds perching on them) with either varnish or epoxy on the underside and edges.
What have you done with yours?
Greg Murphy
S/V Amalia
1965 Cal 30
Muskegon, MI
  #2
Old 05-30-2014
tommays's Avatar
Re: Refinishing Wooden Spreaders
I went with metal and never looked back
But do like Cetol on my wood that takes abuse
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #3
Old 05-30-2014
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Greg Murphy
S/V Amalia
1965 Cal 30
Muskegon, MI
On your Cal and assuming your spreaders are spruce, a good coating of EasyPoxy might be a good finish. Further, you might find that using some thin copper foil to cover the top surfaces of the spreaders will preserve them far longer than any painted on finish. The foil can be cut to shape/size with a good pair of shears and either tacked on with copper tacks (through bedding) or adhered with something like 3M 4200 (NOT 5200!). BTDT
FWIW...
christian.hess likes this.
  #4
Old 05-30-2014
new dad!
christian.hess is on a distinguished road
Greg Murphy
S/V Amalia
1965 Cal 30
Muskegon, MI
all 3(2 actually, as only epoxy is no good)
the white paint is to avoid uv damage and the varnish on bottom so you can see any rot happening or water damage...the white will reflect the uv more hence last longer...the white deterring birds is nonsense...dont see birds avoiding most decks do you? jajaja
on spreaders I have done epoxy and then varnish many times and it lasts a long time...having said that you need at least 6-8 coats of varnish as any varnish work
if you only do west system you have no uv protection...you must top coat with any favourite uv coat...varnish, stain or otherwise
cheers
miatapaul likes this.
1973 Islander 36 "resto" ALMOST there, and ready to SAIL!
  #5
Old 05-30-2014
new dad!
ps the copper foil I have seen on various boats and I love the look of the patina after a while...simply glued on would offer the most protection plus if your boat is classic or older and wooden its looks appropriate
Tags
epoxy , paint , spreaders , varnish , wood
You may post attachments
You may edit your posts
repairing wooden spreaders with mast steps installed dan8152 Gear & Maintenance 13 03-16-2014 05:14 PM
Making wooden spreaders. Material? L124C Gear & Maintenance 34 02-23-2014 09:47 PM
spreaders Leland Gear & Maintenance 22 05-20-2008 06:24 PM
Spreaders sailaway21 Gear & Maintenance 7 04-03-2007 07:26 PM
Looking for Spreaders RookieHunter Gear & Maintenance 5 11-23-2002 04:23 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
