budget estimate for adding roller furling??? - Page 2 - SailNet Community
 4Likes
post #11 of 24 Old 06-03-2014
bratzcpa's Avatar
Re: budget estimate for adding roller furling???
We have a Catalina 27 tall rig. same size luff as yours. This past winter, we ordered and have received a CDI FF6 (with ball bearings). We ordered this from the Sailnet store - best price, just under $800. But be aware - you will need to order the furling line and fairleads separately.
We will be installing this week, so can let you know how that goes. So far, it seems to be well built. You can install over your existing forestay IF it has toggles at both ends. If not, then the forestay needs to be replaced too.
~markb
S/V "New Girl" on the dock
Catalina 27
bratzcpa is offline
post #12 of 24 Old 06-03-2014
If you are not racing, changing out the jib is not a big deal as in the CDI. Same with luff tension. CDIs are well thought out and work effortlessly and don't have halyard wrap problems. Good pricing too.
John
mstern likes this.
ccriders is online now
post #13 of 24 Old 06-03-2014
mstern's Avatar
John
Two big thumbs up here. I have the CDI and for cruising, I think it's the most cost-effective solution. I bought the unit from my sailmaker (who matched the best internet price), and he unrolled the foil and attached it to my stay (the only tricky parts of the process). I then "installed" it on my mast (which was down for the season); it took about 38 seconds. I did not go for the ball bearings, but I have one of the smaller units. Maybe it would be worth the extra dough if you are handling a bigger sail.
mstern is online now
post #14 of 24 Old 06-03-2014
no longer reading SailNet
Alex W's Avatar
The CDI furler runs the jib halyard up and down the furler. This eliminates the option to use a winch to tension the jib's luff. The solution offered by CDI is to run a line up and down the sail tack and furler drum a couple of times to get a multi-part purchase, but there is a lot of friction with this method.
On a standard furler it is easy to get hundreds of pounds of luff tension (if that is appropriate for your sail and conditions) using a mast or cockpit mounted winch. On the CDI furler you would be lucky to get 50lbs of tension. That can have a great effect on the position of the sail's draft.
The Alado copied this part of the design from CDI.
The small size of the halyard, dealing with a messenger line for the halyard, and having to tension the sail's luff in this odd way makes sail changes take a lot longer than on a conventional furler. That makes one less likely to put on the right sail for the conditions.
The money saved on the Alado or CDI furlers might make these tradeoffs the right ones for you, I just think that it is important to be aware of them.
Alex W is offline
post #15 of 24 Old 06-03-2014
Mine cost me under $100 to build 30 years ago to build , but they now cost closer to $150 in materials . I have used the same type of unit since 1980, with no problems.
Huge safety factor, not having to go forward to reef or drop the jib.
Brent Swain is offline
post #16 of 24 Old 06-04-2014
Memopad's Avatar
A couple of thoughts: Halyard wrap is only an issue if you make it one. There are quite a few ways to address the issue and a proper furling installation should remove any potential issues. To me proper installation includes getting the foil as far up the headstay as possible, and having the sail cut/pendants installed so that it gets a full hoist. On most boats that will be good enough, but occasionally you'll need to change the halyard lead angle with a restrainer.
When sizing a furling system, headstay size and length are the critical components. Some units will have boat length recommendations as well, but those are secondary to the headstay length and size.
1978 Ranger 28 and a fleet of Mini 12's.
Ropes and rigging and splicing, oh my!
Memopad is offline
post #17 of 24 Old 06-04-2014
El Chupa Nibre
Mr. Bubs's Avatar
Do you have photos of this? Id' like to see how it's constructed.
Mr. Bubs is offline
post #18 of 24 Old 06-04-2014
krisscross's Avatar
Originally Posted by Alex W View Post
You might find that adding a jib bag and downhaul to your existing hank-on sail provides the ease of handling that you want for a lot less money. The jib bag allows you to store the sail on the foredeck instead of below and doesn't require removing the sail. The downhaul would allow you to douse the sail from the cockpit instead of sending someone forward. I installed a new furler a couple of years ago, but sometimes regret that and wish I had switched to hank-on sails instead.
Very true, but with a furler you can quickly and safely adjust the size of the sail, which IMO is a good safety feature.
Plato
krisscross is offline
post #19 of 24 Old 06-04-2014
Alex W's Avatar
A reef can be added to a hank-on sail that also allows you to do this. It is not as quick, but it is faster than doing a sail change. You have to lower the halyard a little bit, reattach the reef tack (with a little rigging those two steps could be done from the cockpit), and move the sheets to the new clew.
Roller reefing has some advantages and some disadvantages. It is an expensive upgrade and it is worth knowing about the alternatives. It makes sail changes harder than a hank-on boat, which for me is a major drawback. Roller furling gives you a passable but not good sail when you need to reduce sail area.
Alex W is offline
post #20 of 24 Old 06-04-2014
You also need to budget for blocks to bring the furling line back to the cockpit, a rachet block at the cockpit, a cleat, and a halyard restrainer at the top of the mast. Be particularly careful to get the halyard at the correct angle to the forestay and furler, or you'll be getting halyard wraps.
MarkSF is offline
Roller Furling FirstCandC Learning to Sail 7 05-22-2013 02:08 PM
Roller furling Madhatter23 Gear & Maintenance 23 11-14-2010 09:46 AM
roller furling gcouture General Discussion (sailing related) 1 08-08-2010 08:29 PM
Adding A Furling Main To A 310? BVIMoonchaser Catalina 6 04-12-2008 05:18 PM
Roller Furling Dan_T Gear & Maintenance 6 11-02-2001 11:14 AM
