Old 04-12-2006
DRM DRM is offline
DRM is on a distinguished road
Getting Toe Rail Black Again
I have a black anodized toe rail that is faded and chalky. Anyone had any luck making these look good again?
  #2
Old 04-12-2006
jared is on a distinguished road
The problem is that anything you can do to the toerail, will wear. If you paint it, paint wears (especially if you have cars on it). If you use a deck treatment (StarBrite or whatever) it may look darker and shinier--but will need repeated applications to keep it that way.
You may be able to find a reblacking kit from a gunsmithing supply (Brownell's) that will chemically re-etch it, but that's going to be a slow and expensive process.
I'd put a pin-up on the mast to distract the eyes, and just go sailing.
  #3
Old 04-12-2006
Or just color it in with a Sharpie marker...
  #4
Old 04-13-2006
DRM DRM is offline
Jared,
I like your ides of the pin-up.
What do you think of getting one of the models from the boat show to lounge on the deck?
A freind used WD40 and that worked until it rained, then he had black streaks down his hull.
I do not think paint would stay on.
I need something that will soak in.
  #5
Old 04-13-2006
If you can remove the toe rail (unlikely) then you can have it re-anodized if it is aluminum.
You may post attachments
You may edit your posts
Redwood Toe Rail? Artwerke Gear & Maintenance 1 02-14-2006 11:43 PM
Catalina Stern Rail BillG501 Gear & Maintenance 4 01-03-2004 01:29 AM
GALICIA - BLACK RIBBON - NEVER AGAIN Albatros CMF Boat Review and Purchase Forum 0 11-30-2002 02:59 AM
GALICIA - BLACK RIBBON - NEVER AGAIN Albatros CMF General Discussion (sailing related) 0 11-30-2002 02:55 AM
Toe Rail for a Ranger 28 demcshan Gear & Maintenance 0 05-27-2001 09:48 PM
SEO by vBSEO 3.6.1
