Old 04-12-2006
Neicy is on a distinguished road
Zincs
What is the normal number of zincs on a boat and where are they located? I am aware of the one on prop, but where else?
Old 04-12-2006
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Configurations will vary from boat to boat, depending upon size and equipment. Typically, there is a prop shaft zinc and a hull zinc, which is internally wired to electrical ground. Both are shown in the picture of my boat's running gear below.
True Blue . . .
sold the Nauticat
Old 04-12-2006
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
A hull zinc is not that common in my experience so your boat may not have one. If it's not there now, don't worry about it.
The engine also could have a zinc or two.
Old 04-12-2006
zincs
Our practice is to put two shaft zincs on the prop shaft. Install them as per instructions or they could come loose.
We do have a grounded hull zinc as well, but many boats do not. In fact ours is in bad shape but it is a faired-in type that we cannot find a replacement for here on the west coast.
Engine zincs should be in the raw water circuit somewhere.
Old 04-12-2006
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Typically a sailboat will carry one or two collar zincs on the prop shaft, space permitting.
A single, limited-clearance collar can be used in tight quarters (as is frequently found on boats full keels and attached rudders.)
Many boats have a cone-shaped zinc attached to the prop. This is typical when shaft space is so limited that no zinc can fit there. A special prop prop nut is required to accept these zincs.
Most 3-bladed feathering props are designed to accept a zinc as well.
"Clean bottoms are FastBottoms"
Old 04-12-2006
Fstbttms's Avatar
Often a rudderplate or "button" zinc will be mounted on the strut.
Hull zincs are less common, but are frequently found on Taiwan-built boats.
Screw-in "pencil" zincs are used in some engine designs.
Old 04-24-2012
miileeva58@gmail.com is on a distinguished road
Red face Re: Zincs
I just can’t stop reading this. Its so fresh, so filled with updates that I just didn’t know.
I am delighted to see that people are in fact writing about this subject in such a elegant way,
presenting us all diverse parts to it. You’re a fine blogger. Please carry on with it.
I can’t wait to read what’s after that.Thanks so much
Miileeva
Old 04-24-2012
Cruiser2B's Avatar
Cruiser2B is on a distinguished road
Re: Zincs
My Alberg 30 has only a prop zinc, it bolts on the back of the prop.
My two lovely ladies!!
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
corrosion devise jzlatar Gear & Maintenance 4 02-12-2004 06:04 PM
outboard zincs SteveHill Gear & Maintenance 1 01-01-2004 10:32 AM
ProWell Prop Zincs! alohakate1 Gear & Maintenance 1 09-06-2002 01:25 PM
Prowell feathering Prop Zincs Alohakate Gear & Maintenance 0 06-13-2002 04:12 AM
