Slit at front edge of chart table? - SailNet Community
post #1 of 6 Old 06-04-2014 Thread Starter
Hi,
My chart/nav table has a slit (1/4" wide running almost the length of the table). I'm assuming that is made so that some sort of rim can be inserted to keep things on the table? But there was nothing that looked like it would serve that purpose when I bought the boat from the previous owner.
Any suggestions on what this is meant for?
thanks
jballou
jballou is offline
post #2 of 6 Old 06-04-2014
rugosa's Avatar
Re: Slit at front edge of chart table?
Boat model and pics will help
rugosa is offline
post #3 of 6 Old 06-04-2014
Insert edge of rolled up chart so it will not roll back up when you are using it.
Frogwatch is offline
The Following User Says Thank You to Frogwatch For This Useful Post:
jballou (06-04-2014)
post #4 of 6 Old 06-04-2014 Thread Starter
Brilliant! Yes - seems very useful. Thanks very much.
jballou is offline
post #5 of 6 Old 06-04-2014
MikeOReilly's Avatar
We have the same. What Frog says, plus it just keeps the charts from sliding off the table when on a deep heel. If it's not too rough I find it a good place to store a pencil, dividers, or other charting tools.
Why go fast, when you can go slow.
MikeOReilly is offline
The Following User Says Thank You to MikeOReilly For This Useful Post:
post #6 of 6 Old 06-06-2014
It's so you can slide the chart down to look at the upper part while not leaning your wet foulies on the chart. I have several "improve your boat" books that describe that arrangement with similar explanations.
scotthenry is offline
The Following User Says Thank You to scotthenry For This Useful Post:
jballou (06-06-2014)
my 105 epoxy resin... slit my throat 4cylindersoffury General Discussion (sailing related) 22 08-31-2010 11:11 AM
New chart table setup Omatako Gear & Maintenance 10 10-20-2008 02:45 PM
Perfect Chart Table ... wind_magic Sailboat Design and Construction 37 09-11-2008 10:09 PM
Using a portable GPS at the chart table teshannon Gear & Maintenance 49 11-30-2007 09:18 AM
Pocket Cruiser Improvised Chart Table klm General Discussion (sailing related) 2 08-18-2006 09:30 PM
