New MLX halyard for furling gennaker - SailNet Community
post #1 of 5 Old 06-04-2014 Thread Starter
... and having trouble finding guidance on attachment to the sail. I have a Wichard 1/4" D-with-bar, was going to have it spliced on. Second thoughts though, a snap shackle could make the halyard useful as a topping lift, or maybe I ought to just tie it to the furling swivel.
Any best practices that can be shared?
And yes, I am a newbie ...
cliffdweller is offline
post #2 of 5 Old 06-04-2014
no longer reading SailNet
Alex W's Avatar
Re: New MLX halyard for furling gennaker
I use a snap shackle (which has a built in swivel) on my spin halyard. It is spliced in place. It also doubles as a dinghy lifting crane when I bring the dinghy up to the foredeck.
Alex W is offline
post #3 of 5 Old 06-04-2014
Snap shackles are great but I don't use them for critical applications. They can come undone if you're not conscientious about making sure they're fully "snapped" and/or if there's any chance that they'll flog. Whether a spin halyard is considered critical is up to you but I'd go with a standard shackle. Even though the chances of it opening inadvertently are small, getting a spinnaker around your prop isn't fun.
IStream is offline
post #4 of 5 Old 06-05-2014
I don't discuss my member
zz4gta's Avatar
Snap shackle is fine. You want to be able to connect and disconnect with ease. If you're worried about it coming undone, then put a wrap of tape around the pin. The screw shackle takes a while to connect.
Or if you want to go Gucci, use a trigger shackle. Best of both worlds.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #5 of 5 Old 06-08-2014 Thread Starter
Thanks for the excellent responses. My sailmaker is advising me to use a shackle for the main and just go with a knot for the other sails. I will probably follow this "do-no-harm" approach initially, while looking at all other options. Note that the top swivel on the gennaker furler (Harken 1900) doesn't appear to be well-adapted to a shackle of any kind, and also has edges that look like they could chafe a knot.
cliff
Roller Furling Halyard Wrap ebs001 Gear & Maintenance 10 03-18-2013 11:06 AM
Spinnaker halyard for a furling jib?? sfbaysailing General Discussion (sailing related) 13 04-06-2012 12:55 PM
Furling Halyard Swivel Problems sundog01 Gear & Maintenance 6 06-03-2010 01:01 PM
Halyard Tension on Roller Furling System countdemonet General Discussion (sailing related) 6 06-01-2010 05:02 PM
halyard wire wraps around the furling track anderbra Gear & Maintenance 22 06-06-2008 11:10 AM
