Old 04-12-2006
heron237
heron237 is on a distinguished road
Anyone know if a two-lever engine control is being made
26 foot sailboat with a 1gm10 yanmar
My question is does anyone know if a two lever sidemount engine control with
a robust friction adjuster (for throttle creep) is still being made like the
old teleflex morse. It seems they only make a single lever control now.
There is one out there but the nearly 600USD price is out of my league.
Also isn't there a used boat part place in RI, I just can't remember the
name.
Thank you all.
Old 04-12-2006
Throttle creep
We once made our own anti-creep device on a two lever system that worked quite well.
Take a short(2") piece of rubber hose (I.D. about equal to the outer cable cover O.D) and slit it lengthwise. Where the cable connects to the mechanism inside, clamp the hose tightly to the cover, overlapping the exposed cable end that moves. Then apply a small hose clamp over that end and adjust the tension so that you can still adjust the throttle but it provides enough friction to eliminate creep.
Costs next to nothing, is out of sight, ours worked for years ( and may still be doing so - we sold the boat)
Cheers
Old 04-14-2006
TalbotUK is on a distinguished road
The real question is why would you want such a device?
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 05:14 PM
DIY diesel overhaul jeffb General Discussion (sailing related) 2 12-09-2005 05:03 PM
Atomic 4 replacement mr.fixit Gear & Maintenance 4 06-16-2005 04:48 PM
Engine Exhaust/Yanmar Problem plong Gear & Maintenance 5 08-30-2001 10:46 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
