heat exchanger gunk - SailNet Community
Blogs
Old 06-06-2001
creek is on a distinguished road
heat exchanger gunk
I''ve encountered a nasty hardened gunk(like hardened petroleum jelly)in my aluminun heat exchanger, apparently from not flushing the system often enough, or the type of antifreeze(the green stuff). Since the antifreeze mixture passes through cast iron, cast aluminum, and bronze, the ions must be having a field day. Does anyone recommend a coolant/ antifreeze that will be stable?
Perkins 4-108 Heat Exchanger for Sale anaspen Cruising & Liveaboard Forum 0 08-08-2004 10:05 PM
Perkins 4-108 Heat Exchanger for Sale anaspen General Discussion (sailing related) 0 08-08-2004 10:04 PM
Heat Exchanger (Perkins 4-108 loa36 Gear & Maintenance 1 07-10-2004 11:58 AM
Heat exchanger cleanup and cleanout dargiem Gear & Maintenance 2 01-31-2003 05:52 PM
heat exchanger gunk creek Gear & Maintenance 0 06-06-2001 07:54 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
