Main sail can be difficult to raise - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree13Likes
Old 06-12-2014
stuart11 is on a distinguished road
Have a 2005 Pearson Ensign that went neglected for a few years.
Got everything pretty much up & running, but the last couple of sails the main has gotten difficult to raise. I noticed the slugs running into the mast have a fair amount of sway ... they could be catching and getting twisted while going u the mast.
Would a silicone spray help keep the slugs running smoothly up the mast?
Any other suggestions ... including if I've misdiagnosed, are definitely welcomed.
sw
  #2
Old 06-12-2014
tommays's Avatar
Re: Main sail can be difficult to raise
I would look for friction in the sheaves that guide the main halyard
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #3
Old 06-12-2014
Stumble is on a distinguished road
Silicone anything has no place on a boat. I hate that stuff and the spray is the worst, any over spray at all and you will be sanding your decks to get rid of it.
You could try a dry lubricant like McLube on the sail track. It will help, but it could just be that the slugs are torn up, or too loose on the sail. Either will cause binding as you raise the sail. You can also try cleaning the mast track.
Sootydan likes this.
Greg Rubin
Attorney
  #4
Old 06-12-2014
nccouple's Avatar
nccouple is on a distinguished road
I just do the soap trick. A little chunk between the slides every so often. Works wonders and keeps the track clean.
Personally I would stay away from any kind of lubricants. I stained the sail on my last boat doing that.
christian.hess likes this.
oursailingadventures.com
  #5
Old 06-12-2014
new dad!
christian.hess is on a distinguished road
man was about to say soap...any dry wax is your friend
sex wax used for boards works too
youcan test you sheaves first by hoisting a weight on the halyard and going all the way up...if its fine you know its your slugs...
1973 Islander 36 "resto" ALMOST there, and ready to SAIL!
  #6
Old 06-12-2014
asdf38's Avatar
asdf38 is on a distinguished road
My rigger suggested this too, after inspecting the sheaves and seeing no problems.
Though what kind of soap?
1979 Contessa 26
Boston, Ma
  #7
Old 06-12-2014
RichH's Avatar
RichH will become famous soon enough
1. Scour out the slug track ... go up the mast and CLEAN the slug track
2. LUBE the whole track with McLube or other 'dry' teflon lubricant ....
3. carve a piece of paraffin wax (candle, etc.) to the same diameter of the cylindrical dimensions as one of your slugs and place it into the sail slug groove and in-line between the topmost and second from the top slugs as mounted onto the mast sail track groove - it will lubricate any spot or 'roughness' that's missed with the McLube every time that you raise / lower your sails.
The Following 2 Users Say Thank You to RichH For This Useful Post:
christian.hess (06-12-2014), stuart11 (06-16-2014)
  #8
Old 06-12-2014
new dad!
oooooh nice tip Ill try that next time...
  #9
Old 06-12-2014
Irrationally Exuberant
arf145 is on a distinguished road
Forgive me for stating something so fundamental, but have you released the mainsheet before you raise the main? If not, you are fighting the boom. A guy I know (no names, please ) made this mistake more than once early on.
deniseO30 likes this.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
  #10
Old 06-13-2014
RichH's Avatar
Good point. Also release the vang too.
You may post attachments
You may edit your posts
Young sailors sail around Nakheel’s The World to raise funds NewsReader News Feeds 0 02-16-2013 04:00 PM
New sail or raise sail position on mast? ehroe2 Gear & Maintenance 10 06-24-2012 03:41 PM
Help what sail to raise 1st? Lou452 General Discussion (sailing related) 37 06-01-2012 12:20 AM
raise boom end 6" with new sail jackytdunaway Gear & Maintenance 9 02-10-2010 02:42 AM
Raise Boom/Shorten sail Neicy Gear & Maintenance 8 12-28-2005 11:50 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
